Old 05-29-2004, 05:25 PM   #1
Jayberg00
Jayberg00's Avatar
Ls turbo
what injectors should i put in the Ls to upgrade the fuel system for turboing, what kind of fuel pump should i use, what about the fuel rail should i change or not, rememberr this is a stock 92 Ls motor, how much pounds of boost should it be set.
Old 05-29-2004, 05:36 PM   #2
Injectors are dependent on how much boost youre going to run
stock pump and rail should be sufficient...depending on boost
how fast do you want to go?
built internals or stock?
