Old 05-22-2004, 06:06 PM   #1
AkimboStylee
AkimboStylee's Avatar
okay my civic has stumpped me
i go to start my car, and i wont start, i checked the battery and it is fine, what are some possibilities of the problem.
there is no sounds coming from anywhere, so i dont know what it could be, 2 options are the clutch, and starter, and what some ways to check to check this,
pdiggs, i need your help!!!!
Old 05-22-2004, 06:30 PM   #2
does it get power? does it crank at all? how close to starting does it get?
Old 05-22-2004, 06:32 PM   #3
AkimboStylee
it doesn't even start to crank, and i have head lighs, sterio and all internal electronics
Old 05-22-2004, 06:48 PM   #4
so it just sits there eh
have you checked spark/fuel?
Old 05-22-2004, 06:52 PM   #5
AkimboStylee
well i found out the problem, i got to start, roll start, so it is the starter, but i dont know much that is going to put me back.
Old 05-22-2004, 06:53 PM   #6
if its not cranking at all then its godda be something related to your starter. without ignition it will still crank, just not turn over. maybe a ground came loose or something
Old 05-22-2004, 07:27 PM   #7
take a hammer and bang a bit on the starter. that should be able to fix it for a while. a starter will prolly run you around 2-300
Old 05-22-2004, 10:05 PM   #8
AkimboStylee
actuallt starter was 79.99, but they tested it and it wasn't the starter, it was the nuetral saftey switch.
Old 05-23-2004, 04:27 PM   #9
yeah, i have that problem too (on the escort) just be sure to push the clutch in ALL the way as hard as you can. Unless the switch is completely hosed. i can't imagine it was too much.
Old 05-23-2004, 08:43 PM   #10
AkimboStylee
well there is a rubber grommet to protect the metal piece, that gets pushed, well that piece went bad, so i used a bolt about the same size, and no it works as if it had no problem. and the starter was the easiest thing to remove , only two bolts and they are both on top!
