Old 05-16-2004, 01:20 PM   #1
So Im going to make some spacers
Spacers that would raise the spring perch on the koni's around .5" in the front and .25" in the rear.
So...
Im going to buy a 10" tube section, and was curious as to whether I should use Aluminum (6061) or Stainless Steel (t304).
The price difference is nearly 2x as much for stainless...but I think it would hold up better....specifically because I plan on making a 1" set for the winter.
What do you guys think?
Oh, the Dimensions of the tube are:
OD - 1.900
ID - 1.610
Wall Diameter - 0.145
Id have to do some enlarging and grind out the lip too.
Old 05-16-2004, 02:44 PM   #2
AkimboStylee
AkimboStylee's Avatar
sounds like you have some work to do, i would take it to a machine shop, cause i know i would screw them up!
Old 05-16-2004, 02:45 PM   #3
AkimboStylee
oh and go for the stainless, they will hold up better than the alluminium
Old 05-16-2004, 05:24 PM   #4
eh I think I can do it w/ a lot of patience and a lot of grinder bits
If not....time to head to the machine shop buddy
I bought the 6061 Aluminum tubing from onlinemetals.com
$5 for 10" is alright
(changed order...leary about working w/ the stainless)
Old 05-17-2004, 12:19 AM   #5
why would you make a 1" set for the winter?
Do you lower your car MORE in the winter?
Also why bother making them if it's just to get .25-.5" of travel extension... I don't think that will improve the shock performance much unless they're already the shocks designed to be on a lowered civic... in which case I don't think the .25-.5" will really affect their performance too much...
Just my thoughts.
Old 05-17-2004, 12:38 AM   #6
take pics
Old 05-17-2004, 01:12 AM   #7
it has nothing to do w/ shock travel or performance
These arent spacers for the top-hat for shock travel...theyre for the spring perch to raise ride height slightly
Borrowed from CivicLX H-T
See the rear koni's have 3 spring perches...fronts have only 2. You can raise the ride by changing where the perch is w/ a circlip and ring combo.
I am going to make taller rings to sit on the circlips to give me a slightly higher ride since I already use the highest (stock) perch and its too low...so .5" lift will work nicely.
(I dont want the full 1" in the rear)
Old 05-17-2004, 08:06 AM   #8
biker's back
I would have spent the coin on the stainless. From my experience with mentals, especially under load; stainless is nicer.
Old 05-17-2004, 09:43 AM   #9
but 10x harder to work with
it wasnt a cost issue
Old 05-17-2004, 10:24 AM   #10
biker's back
haha i just typed mentals, not medals. And you're right its harder to work with. Anywho, just remember that alu has a short life and you shoudl keep an eye on it.
Old 05-17-2004, 01:23 PM   #11
its probably only a temp thing anyway
Im not concerned
(and its meTals )
