Old 05-09-2004, 10:20 PM   #1
Short Throw Shifters
OK i definatley need a STS, the stock throw is killing me, so i could use some suggestions. There's just too many to choose from. I was wondering the differences between single/double bend, and some that are adjustable etc.
Thermal, i noticed on your civic, the shifter like curls up, i'm assuming it's so you don't have to reach your arm into the dashboard to shift. How do you like it and where did you get it?
Old 05-09-2004, 10:43 PM   #2
i like my DC sports shifter.
Old 05-09-2004, 10:45 PM   #3
How much? where'd you get it? how noticiable of a difference etc etc.
Old 05-09-2004, 11:04 PM   #4
I love my skunk2 dual bend...I used to have a B&M that rattled w/o rubber washers and was waaaay too far away for me to enjoy. I dont think I could comforably go back to a stock civic shifter.
The difference of the bends is how close the knob will be to you and the angle of it.
The dual bends tend to be closer
Just remember...shifting faster wears synchros quicker. DO NOT "race/quick shift" all the damn time. Shift slowly...like grandma does.
Cheaper shifters are known to break, literally in 1/2, when it comes time to race (legally!).
On a side note, a lot of people just change to a stock integra or sometimes del sol shifter. Both are "shorter" than civics and you retain stock quality. Neither of them are as short as aftermarket...which may be good if you think youre going to be slammin gears all the time....................no self-restraint
Old 05-09-2004, 11:06 PM   #5
Mine is a dual-bend focuz short throw for a Teg... not a civic. I like it but.... here's a little secret..... get a stock del sol shifter. Those are awesome since it is pointed towards the driver and still shorter than stock. I will trade the short throw from my Teg to a stock del sol shifter sometime next week.
Old 05-10-2004, 12:58 AM   #6
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
del sol shifters will bolt on to any civic right?
RICE....is good
Old 05-10-2004, 04:18 AM   #7
Skunk2 Dual-bend...
Don't forget to buy the 'weighted knob' too!
Old 05-11-2004, 12:29 AM   #8
a96710
a96710's Avatar
I just got my dual bend short shifter on, it's great
Old 05-11-2004, 01:26 PM   #9
yea i ordered a skunk 2 dual bend, 130 with 2 day shipping so i should have it in.... uhh 2 days!
Old 05-11-2004, 04:22 PM   #10
did you get poly bushings to go with it?
Old 05-11-2004, 07:20 PM   #11
no comprende espanol, transduce en ingles por favor.
Old 05-11-2004, 07:32 PM   #12
sohc_vtec 2NR
he means the polyurethane bushings, the stock piece comes with rubber bushings; over time, the rubber pieces get soft and doesn't offer the firmness of the polyurethane pieces
RICE....is good
Old 05-12-2004, 06:41 AM   #13
ah ha, thanks for clearing that up, where could i find some poly bushings? i could always install them later i suppose right?
Old 05-12-2004, 11:01 PM   #14
sohc_vtec 2NR
you can install them later if you wish, but my question is WHY? you'll have to remove the shifter linkage which holds the bushing, since its out of might as well replace it right there and then. unless you like to waste your time...
RICE....is good
Old 05-13-2004, 06:38 AM   #15
Kool-Aid
I had bought a B&M short shifter kit...is B&M a good brand?
Old 05-13-2004, 07:59 PM   #16
i'm good at wasting time also, i need a short throw now, i don't know where to get those bushings, and even if i did i'm dead broke.
Old 05-14-2004, 03:17 PM   #17
Honda_Tengoku
i had polys on my shifting linkages on my Z6 hatch. I hate polys on upper and lower control arms on a suspension, but on anti-sway bars, and shifting linkages they are worth their weight in gold! Mine were from energy suspension. Good luck.
Old 05-14-2004, 11:07 PM   #18
Well i got it installed. Wasn't too bad but had to figure some things out since it didn't come with instructions but i must say i love it. Takes away a lot of fatigue around the city and is much faster for my 0-60 runs.
Old 05-15-2004, 07:30 AM   #19
Kool-Aid
How long does it usually take to install an STS kit?
Old 05-15-2004, 08:55 AM   #20
well if i had instructions it probably would have been about 10-15 minutes shorter, but basically you jack up the car, take off your shift knob and undo the screws that hold in the center console. Then you go under the car, undo the bolt that holds the shifter linkage to the STS itself, then there's two bolts that hold a cuppy thing that holds the STS into the car. then just reverse the process. I figure anybody who can jack up a car, and turn a couple of wrenches can do it.
Old 05-15-2004, 10:15 AM   #21
once you get another $20 you should invest in the bushings...its like "brand new"...not just "new" feeling
Old 05-15-2004, 11:08 AM   #22
Kool-Aid
ok...I was gonna try to do it...but after I leave this wretched place...I'll have a whole month off so I'll have time to fix it if I screw up...
Nobody ever said anythign about B&M...was that a good brand to get because that was what I had got...
Old 05-15-2004, 12:35 PM   #23
Originally posted by pdiggitydogg I used to have a B&M that rattled w/o rubber washers and was waaaay too far away for me to enjoy
first page
it does give the shortest throws, by far, though
Old 05-16-2004, 12:17 AM   #24
where can i get the bushings from?
Old 05-16-2004, 03:12 PM   #25
sohc_vtec 2NR
the bushings are all over the place, to name a few:
http://honda-tech.com/zerothread?id=854465
http://honda-tech.com/zerothread?id=717096
http://www.importparts.com/shop/inde...Path=1800_1804
just search for civic shifter bushing and there are tons of sites that sells them
RICE....is good
Old 05-16-2004, 05:31 PM   #26
I think I got mine from nopi
Old 05-17-2004, 07:22 PM   #27
Yes... and on Teg's too
Old 06-01-2004, 11:20 PM   #28
NAPALMsunrise
Ok where?
Does anyone have a web site or anything that has shifters and information! I read this thread and wanna learn more about dual bend and all that shmazz
Old 06-02-2004, 06:27 AM   #29
Pretty much..........just ask and we can tell you (...probably)
Old 06-10-2004, 05:56 AM   #30
SuperHero500
The best short shifter I have found is to take the stock shifter cut it fairly high above the "ball" and cut again at bushings/shiftlinage hooks now flip the piece so that the longer part is on bottom instead of top reweld the linkage to the now longer end (make sure you have removed the bushings before welding and reinsert after it has cooled). if you want it extremely short you can cut more off the top part to make the top shorter, re weld and install... it's cheap, custom, and is the best functioning.
Old 06-10-2004, 08:53 AM   #31
Got measurements? Not bad but if you could do a how to in the step by step section since that would be helpful, a friend of mine was considering doing that but he didn't want to mess it up.
Old 06-10-2004, 09:45 AM   #32
Its almost impossible to screw up.
First undo the knob from inside and remove the center console.
Then just remove the middle exhasut hanger so you can push it to the side (or you can take the whole thing down).
Then just unbolt the old shifter and pull it down.
Put in the new one (this is the only part that is even possible to screw up.......you could put it in backwards...)
Put your stuff back and call it a day.
Some shifters require you to reuse the stock shifter wieght/ball's bushing...some dont. That'd be easy to figure out by just comparing the two.
An important note: Do not make the shifter bolt too tight or else you will not be able to shift since the forks will be squeezing the end too tightly.
Thats it
Old 06-10-2004, 08:10 PM   #33
haha i know how to install it pdiggs i did my skunk 2 myself! lol i was wondering how to cut the stock shifter down and flip it around like he was talking about because i always thought shifters were weighted or something and that modifying it like that would mess it up.
Old 06-10-2004, 08:29 PM   #34
my bad...I just didnt read :o
Old 06-10-2004, 09:28 PM   #35
bent_remy
bent_remy's Avatar
I have (had b4 i blew the engine) a b&m short shifter, 59.00 on ebay and I was very pleased with it.
Civic Dx 2 Si
Ya heard!
Old 06-10-2004, 09:36 PM   #36
yeah i think my friend ordered a pacesetter shifter for his car, although i'm not sure about their products, they sound a little sketchy to me. It's supposed to reduce throw by something like 80% ?!?!
