Old 05-05-2004, 12:37 AM   #1
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
oil feed line problem
After installing my greddy kit, i had a leak in my oil feed line and i finally got the time to fix it, but as usual i run into problems. Here's a picture:
Problem: the oil line won't fit into the banjo fitting, the oil line is smaller than the banjo fitting
Possible Solution #1: tighten the f*ck out of it and hope it seals...
Possible Solution #2: buy some sort of "adapter/fitting/connector" that will connect both pieces together...
So where do you think i can find an adapter/fitting/connector?
RICE....is good
