Old 04-10-2004, 03:14 PM   #1
Mirkwo0dForest
Fan problem
so i was wondering... i just hooked my fan back up and i wanted to know, is it supposed to come at a certain temperature or as soon as i turn the key?
Old 04-10-2004, 03:27 PM   #2
Yes, via your thermostat rating
Old 04-10-2004, 09:31 PM   #3
Mirkwo0dForest
ok, cool man, thanx!
Old 04-12-2004, 04:19 PM   #4
Mirkwo0dForest
oh, so i guess my fan isn't turning on
my radiator is pumping fluid but the fan aint doing anything... anyone have a clue, i have 2 plugs plugged up on it, is there sumthing i'm missing?!?!
Old 04-12-2004, 05:39 PM   #5
V8killimports
V8killimports's Avatar
Fuse? Bad sensors? Wiring backwards?
Old 04-12-2004, 05:53 PM   #6
or your engine is too cool for the fans to start
Old 04-13-2004, 06:20 AM   #7
Mirkwo0dForest
but wouldn't they start when the radiator starts flowing?
Old 04-13-2004, 08:14 AM   #8
nope. they should start when the coolant tempp is at 196 for the rad fan and 212 for the condenser fan. try pushin in the ac button and they should start
Old 04-13-2004, 04:31 PM   #9
the coolant flows regardless of temp
fan kicks on at certain temp
You can test the fan's fuses, wirings, etc to see if its connected right, or test the fan itself by hardwiring it to the battery for a test (use spade clips)
Or, just drive around for awhile, let the car heat up, drive home, let it run and listen for the fan to come on.
After I did my rad upgrade my fan didnt come on and I thought something was wrong (relay, fuse, wires, blahblah). Turned out it was just more efficient and the fan didnt have to come on yet. It could be that its just cold enough outside.
You are driving a teg now, and its rad is 2x the size as the civic one you had before. That could be all that it is.
Old 04-14-2004, 06:27 AM   #10
Mirkwo0dForest
good point... thanx for giving me an excuse to drive it today :-)
since i dont have the ac compressor anymore, could i just hook that fan up to the battery and make a switch to turn it on and off? it sounds feasable...
Old 04-14-2004, 12:02 PM   #11
you could
but you could also wire it through the other rad fan so they come on at the same time.
Old 04-14-2004, 02:38 PM   #12
Mirkwo0dForest
now that's an even better idea... cuz i might 4get about the switch... lol
