Old 04-01-2004, 04:56 PM   #1
VR4_Craver
Banned
Underbody lights....
I havent got the slightest clue how to do these. Should i just drop 50 bucks and have it done right??
Old 04-03-2004, 10:14 PM   #2
VR4_Craver
Banned
DAMN IT SOMEONE ANSWER!!!!!
Old 04-04-2004, 01:42 AM   #3
Dude, there should only be 2 wires on any lighting:
1) mount the light anywhere you want to
2) ground it (black wire)
3) power wire to the positive side of the battery.
I recomment to use at least a 10 gauge wire. Once you run a wire on one lighting, you can tap the rest to it unless you want a separate switch for each individual light........... very simple.
Old 04-04-2004, 09:49 AM   #4
A kit like that doesn't come with directions? well even if it doesn't i'm sure it's similar to my neons in my footwells (aside from the fact that you kit may have transformers or relays). Anyhow pretty much figure out which wire is which, run a wire from you batttery with an inline fuse (very important) and before you install anything make sure you don't have a fuse in it (hence no power and nothing can get damaged). then find a suffficient ground, make sure they're mounted and wire it all into a switch in the car. then insert the fuse. good luck
