Old 03-29-2004, 01:01 PM   #1
1 slow D
high idle now
I'm a novice.......need help!!!
Recently I installed a timing belt/water pump onto my civic. It was rather easy having mechanical background however this is the first honda engine I have touch in regards to these parts. I looked at the timing marks on the crank and cam gear, for some reason they seemed to look almost a 1/2 tooth off all the time. I tried to correct for this, but all I ended up with was the same 1/2 tooth off look. Maybe I'm seeing shit, who knows.
When I started my car up it high idles around 1500rpm or so. I figured it was just the warm up stage so I let it warm up, nope, it high idles even after I try to kick down that idle its still up there. It idled fine prior to my messing with things.
Any ideas would be helpfull.
Thanks in advance.
Old 03-29-2004, 03:11 PM   #2
1 slow D
Just sitting there playing around with it and monitoring my vtec on the afc. When the vtec kicks in around 5k it sputters a lot, doesnt fall on its face, just sputters. Has a check engine light also.
Old 03-29-2004, 03:59 PM   #3
1 slow D
Another thing I forgot to mention is its turbo charged........good mistake eh!!!
Throttle cable is good.
I went out and rented a scanner from checker auto parts, hooked up says I have a 108 code which is a MAP circuit high input. I have a check valve from turbonetics on there so maybe that went bad, cant wait to get a price on that baby.......................
Old 03-29-2004, 06:25 PM   #4
i dunno what to say man. did u advance the ignition timing by any chance ? i know when my map sensore went bad the idle dropped to almost nothing
