Old 03-29-2004, 04:03 AM   #1
pbateson
How to removed the corner lense?
I cannot removed the corner lense to replace a new blub.
What I do?
Old 03-29-2004, 09:34 AM   #2
MAXed Out
6th Gear
MAXed Out's Avatar
You dont have to remove it to change the bulb paul. There is the little knob that u twist and the bulb and socket come out from the corner lens. But that is on my nissan and integra so it might not work on your accord.
SHIFT_MyNuts
Old 03-29-2004, 12:51 PM   #3
why would you replace the new blub. i dont get it.
it should just a screw holding in there. it usually behind it or above it. then just push it out.
Old 03-29-2004, 01:20 PM   #4
If you have to take out the corner lense, unscrew the single screw on top of it. Off the top of my head I don't think there are any more. It requires a little bit of elbow grease to pop out. Pull it straight out toward the front of your car.
Old 03-29-2004, 01:39 PM   #5
thats exactly how preludes corners are
Old 03-29-2004, 01:54 PM   #6
pbateson
I did one screw on the top, and it will not come out. It is a pax side corner lense, and then I need a replace a bulb because this bulb was burn out.
Understand?
Old 03-29-2004, 02:00 PM   #7
If you unscrewed the top one and you don't see any more, gently pry it out with something. It will slide straight out toward the front of your car. Don't pry it any other direction because there are tabs that will break.
