Old 03-21-2004, 09:15 PM   #1
dxkdogs
turbo vafc hack
ok, i put in a set of 440 cc injectors and a did vafc hack to run the injectors. The car starts on the frist try but it idles about to 400 to 500 {which is very low} and when i give it gas it studder to pick. I can't even drive around the block. My setting are all the same on lo/hi and narrow /wide. I have the vafc2 with the black face and the TH-POINT is set at narr. 10% and the wide is 50%. what is the low and high here. Should i set it to 98% low and 99% high???like the older vafc...any help here...
1-2.5k -40%
3k -40%
4k -35%
5k -35%
6k -35%
7k -35%
8k -35%
9k- 35%
Old 03-21-2004, 10:16 PM   #2
It appears that you maybe to lean. Fiddle with the Narrow low cam and give it a little bit more juice. Set 1000 RPM at about -35% and add more to bring up your idle. 10% and 50% on TH-POINT may also be your problem. Try bringing it up to 72 lo and 73 hi. That is where honda ECU go to close loop. Goodluck...
Old 03-22-2004, 02:28 AM   #3
Sivik
ive also noticed with mine that sometimes while driving on and off the gas there is a hesitation or a jerk if you want to call it that. im pretty sure this is normal for all AFC hacks.
what are your other settings at? Sensor type, car select... those settings? they make a difference too.
Turbo'd 98 Honda Civic EX
My Car
My Car is for sale
Old 03-22-2004, 09:47 AM   #4
mine does that too and it's stock.
Old 03-22-2004, 11:37 AM   #5
dxkdogs
ok i'll try it out and let you guys let later. i'm sure all the other setting are right { Sensor type, car select }
Old 03-22-2004, 09:05 PM   #6
dxkdogs
vafc hack
hey guys, i got it to ilde right but now there blue/white smoke coming out of my exhaust..What can this be?
Old 03-22-2004, 10:27 PM   #7
Sivik
white smoke = burnin oil = bad thing
how new is your turbo?
My Car
My Car is for sale
Old 03-22-2004, 10:45 PM   #8
sivik, change your spark plugs..... also OBD1 ownzzz. Never had that hesitation problem ever since I converted.
Old 03-23-2004, 12:46 PM   #9
dxkdogs
My turbo is brand new. What kind of spark plug should i use and i noticed that they are black.
Old 03-23-2004, 04:49 PM   #10
Sivik
i change my plugs like once a month... use NGK 1 step colder than stock. I've thought about converting, whats required other than the ECU?
new turbos will smoke due to the seals setting and all the other crap inside burning out. it should go away after a day. if not then you might have an oil leak on the turbo exhaust side, but if its new i highly doubt that.
My Car
My Car is for sale
Old 03-23-2004, 10:39 PM   #11
OBD1 conversion harness from boomslang ($75 shipped). Get a P28 manual ECU. It so much of a difference man.
Old 03-30-2004, 11:24 AM   #12
Mirkwo0dForest
if you've never done it before, i'd also recomend changing your plug wires... not too expensive, you prolly need them, and they help on the acceleration stuttering problem a bit also
Old 03-31-2004, 09:37 PM   #13
If you are still smoke white smoke, check your oil return line. If it is pinched, it will back flow to the turbine outlet side and through your exhaust system........
