Old 03-21-2004, 09:08 AM   #1
soundspeed
soundspeed's Avatar
Wipers Don't Work Properly
I have a 98 civic and there is something wrong with my wipers. My intermitents don't work, as well as when I spray washer fluid on the windsheild the wipers don't come on. All I have is low and high speed. Any suggestions on what the problem could be. It is very frustrating. Oh yeah one more thing, has anyone ever used drop zone coilovers, and if so what r your opinions about them.
Thanx guys.
Old 03-21-2004, 10:03 AM   #2
you wipers arent supposed to come on when you spray...civics arent special enough to have that feature
as for the settings check your relays...its probably blown
dropzone anything is trash
Old 03-21-2004, 02:41 PM   #3
Sivik
Umm, before I switched to a CF hood, my wipers came on while I was spraying and stayed on for like 3 more swipes after stopping the spray.
I agree with you on the relay part. check those as well as fuses to see. get yourself a helms manual or something along those lines so you can trace the wires. also, BrandonClaps is the Guru of wiring so ask him as well and he can help with that.
Turbo'd 98 Honda Civic EX
My Car
My Car is for sale
Old 03-21-2004, 08:33 PM   #4
most civics (like everyone Ive been around) dont so i am really surprised that yours wiped w/ squirting
Old 03-21-2004, 09:29 PM   #5
soundspeed
soundspeed's Avatar
Thanx for the input guys. I just assumed that they would move when squirted my other car was a '93 and it did it.
Old 03-22-2004, 01:42 AM   #6
my wipers do come on when I spray....but not on my teg tho
Old 03-25-2004, 06:03 PM   #7
autocrossthugg
autocrossthugg's Avatar
I had a problem with my wipers a while ago. I took my car to the dealer and they replaced the wiper assembly. (defective, recall from Honda) Check with the dealership if your car is under warranty. Good Luck.
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
