Old 03-20-2004, 08:03 PM   #1
wreckless
NA, Vtec, Turbo or Charge. What should i do with my B20?
Just a simple question... its just that i've got so many opinions about what i want to do with my B20... I originaly wanted to start with a Vtec Frankenstine... but ppl tell me that i'll have problems with leaks and engine life after like 30k miles... so i asked around about turbo and Super chargeing... then they tell me that it requiers alot of high maitanance... But i know that i cant get much by just going NA... Balls to the wall thats what i want to do with my B20... any one got suggestions... NA? Vtec? Turbo? SC?
Old 03-20-2004, 11:40 PM   #2
Turbo. but you should upgrade internals and do the basic modifactions to your B20 first.
you dont want to turbo car and have the internals not beable to take the boost and fry everything. then you have to start over.
Old 03-22-2004, 10:26 PM   #3
turbo. if tuned right the maintenance won't be required that often.
Old 03-23-2004, 03:19 PM   #4
wreckless
what else should i do
besides pistons, valves and rods is there any other things i should upgrade?
Old 03-23-2004, 07:03 PM   #5
mugendude
you'd definitly need to resleeve the block
Old 03-23-2004, 08:41 PM   #6
c0ng0 b0ng0
im not sure i understand i think the b20 is the new model of honda but either way i say turbocharge and cold air intake
Old 03-23-2004, 09:01 PM   #7
a b20 is a motor
you cannot use cold air intake and a turbo together...
If I were you, and I must say ive pondered this thought many times (motor wise), I would take the b20 and resleeve it for boost. Turbo b20's kick major ass, but the sleeves tend to die out at or around 6psi or more.
Once you do that, boost it up and use a b18 ls cams for slightly more aggression
Old 03-24-2004, 04:22 PM   #8
wreckless
Okay think i got it new stronger valves, rods and resleeve the b20 block... didnt know much ppl didnt know what a b20 is... for you that dont know its a honda CRV engine... ne ways i guess majority say Turbo the dam bitch... ne more tips hints etc...
Old 03-24-2004, 04:24 PM   #9
wreckless
Can i use stock internals from a gsr for turbo and not worry... will i have to run under 6psi...
Old 03-24-2004, 10:39 PM   #10
C's 94 InTeGrA
C's 94 InTeGrA's Avatar
IT depends. ON milege. I say u would be safe if u ran less than 6psi but being very careful. But id go ahead and do them just to be on the safe side
Old 03-24-2004, 10:58 PM   #11
It really depends on what you want out of the motor.
Were it me, Id start w/ resleeving and boost it up to 8-10psi.
The b20 is just a bored out LS integra block and everyone knows its components are pretty decent.
If you plan on going over 1bar Id advise on going w/ pistons too.
Old 03-25-2004, 07:20 AM   #12
wreckless
so what im getting is that the stock internals will be good to handle the psi as long as i resleeve the block... and also keep it under lets say 7psi???
Old 03-25-2004, 11:44 AM   #13
If youre keeping it around/under 7psi resleeving alone the motor will definately hold up.
The rods are the same as b18b/a and theyre not wimps, really. LS rods can daily take the boost upwards of 12psi. Shotpeening the rods is an option, that would give them a bit more strength as well.
I know the stock b20 pistons would hold 7psi, no worries, but if you planned on going higher and are concerned about them, you might as well go aftermarket since you already have the entire crank out for resleeving. But it is NOT necessary IMO.
Old 04-15-2004, 03:18 AM   #14
dcb16
dont listen to pdiggity... you cant rev b20's anywhere without internal work.
depending on your budget, bore/resleeve
get a vtec head and intake mani. (and you cant just slap on the vtec head and expect it to run correctly, you have to do a lot of machine work. ie, plugging oil holes, boring combustion area, boring out head gasket, ect. check this site out http://www.b20vtec.com/frontpage.html
rods, and forged low compresstion pistons if you wanna boost it, gsr (or ctr/itr if you can afford) cams,
steel crank
that is a good start for b20/vtec turbo let us know what you decide
