Old 03-12-2004, 01:47 PM   #1
Blk96DX
need help
ok i had a dx civic and wrecked it. so i took my apexi n1 off it and put it on my 2000 civic ex i also had an airmass header i put on the ex too. but the header is shot so i took it off but during the process of putting the n1 the o2 sensor on the bottom of the car in the floorboard which was in the resonator was stripped out so i just cut it to put the new mid section on and now my speedometer doesn't work nebody know y is it cause of me cutting the o2 sensor or something different ne help will be appreicated
Old 03-12-2004, 02:49 PM   #2
well cutting the o2 sensor shouldn;t affect the speedometer, unless you cut the cable there. i am not sure if those cars have cable or electronic speedometers. i would look for extra wires that you cut there. i know on the accord that i have one of the vss's is right next to the a-pipe and the cat.
Old 03-12-2004, 06:03 PM   #3
very strange...did you check the fuses?
it may be something as simple as that...though I really wouldnt have any other idea
Old 03-13-2004, 01:18 AM   #4
Blk96DX
i checked the underhood fuses and some of the fuses under the steering column they all seemed fine i have no clue i asked one of the tech's i know at the honda dealership and he said it was probably just a fuse didn't which fuse just one of the fuses so i guess im going to have to examine ever fuse thanks for the help though
Old 03-13-2004, 10:13 PM   #5
Shaved &/or Laid
Shaved &/or Laid's Avatar
if not a fuse, then...i dont know
Doody Ej1
Yse.
