Old 03-08-2004, 04:35 PM   #1
Senshi
termostat stuck???
ok i got the thermostat out of my car, and i'm not sure if its stuck or not just by looking at it, i was doing an oil change and thought that i would check it out also, just to keep up on things, now the thing on the bottom that slides up and down, still slides, so i'm guessing that its not stuck, is there anything else to look at on it just to make sure
Old 03-08-2004, 06:03 PM   #2
does your fan turn on? Does it open when you place it in heated water?
Thats a good way to tell if its ok.
Old 03-08-2004, 06:04 PM   #3
Honda_Tengoku
if your car isnt overheating your prolly good too go. I wouldnt worry about it. BTW its not necissarily that it can move up and down it depends on whether it reacts (wax pellet inside) to heat correctly (if I remember correctly).
Old 03-08-2004, 06:06 PM   #4
Senshi
well my temp gauge is broken, no needle, ugh, but i put it all back 2gether its pretty new, the thermostat that is its about 9-12 months old so it shouldn't have a problem, i know i have a heat problem, but i just need to find out where its coming from, and i need to replace the heater valve thats on the firewall, but now i'm about to go out and buy some pipes thanks for the info
Old 03-08-2004, 06:48 PM   #5
if your temp needle is broken you should really get a replacement cluster or at least that part of the cluster...if not then its an excuse to get an aftermarket water temp gauge
Old 03-08-2004, 07:00 PM   #6
Senshi
yea i know i'm going to get an ex gauge cluster, that is when money is alright again, i really need to get one
^_^ TAX RETURN ^_^
Old 03-11-2004, 11:47 PM   #7
thermostats are cheap... heads aren't...
I'd change the thermostat... You should do it every 2 years anyway.... they can last longer than that but do you really want to wait till it goes?
Old 03-11-2004, 11:48 PM   #8
oh and I'd go for a failsafe thermostat... when they do go bad they break open not closed... so instead of you figuring out the thermo went bad by overheating... you figure it out by it taking your car MUCH longer to come up to temperature on start up...
Much safer much better.
Old 03-12-2004, 09:17 AM   #9
do u fell the engine warmer than usual when you pop out the hood ? might be you have some air inside the cooling system, the water pump might be going (60-90k miles life span on those), some stuck coolant passages, or the thermostat
