Old 03-02-2004, 11:51 PM   #1
luvmy96honda
distributor help please!
If you know anything on a tec distributor that goes to a 96 honda accord lx f22b2 engine, please help. I need to know after you take off the cap,rotor,and the black cover piece, theres a metal plate with 3 screws, when i take off the 3 screws i try to pry it off but will not budge. behind the metal plate is a black box with a yellow and black wire connected to it, is that the internal ignition coil? My manual does not cover this distributor.
Old 03-03-2004, 02:57 PM   #2
it might be either the coil or the igniter unit.
which of the things in the pic blow are u talking about ?
http://www.hondaautomotiveparts.com/...UTOR+%28TEC%29
Old 03-03-2004, 05:08 PM   #3
luvmy96honda
on section 5 the housing, look up front of the housing, rihgt above where the icm goes is the metal plate. look at my pic the red is the area im talking about the blue is the 3 screws. how do i get that piece off? Also what is piece 11? never says on site. please help!
Old 03-03-2004, 05:45 PM   #4
11 is the coil.
Old 03-03-2004, 08:05 PM   #5
luvmy96honda
where is that coil at in the distributor? is it the black box in the back of it that has the black and yellow wire going to it? heres the reply from accel, That kit is a remote coil mounting kit. You'll have to run a RPM signal wire to the (-) coil lead and a +12 wire to the coil. what ever that means.
