Old 02-15-2004, 11:56 AM   #1
allglock
Engine noise?
I recently bought a 1999 Civic DX with 46K on it. The motor seems noisey to me. It is worse cold. It is kind of like a hollow metallic knocking sound. I cant determine if it is in the top end or bottom. Any ideas? BTW it is a 1.6L SOHC motor. Thanks!
Old 02-15-2004, 12:06 PM   #2
i think it's time for a valve lash adjustament. i guess you don't have any clue when it was done the last time, but honda reccomends it every 15k miles.
Old 02-15-2004, 05:06 PM   #3
allglock
How much to get that done?
Also does it make sense that it gets alot quieter as it warms up?
But even warm you can still here a slight noise.
When cold and revving the motor it almost sounds like marbles rattling.
Also my brother in law has a 2000 with 60K and has never had the valves adjusted, and is totally quiet???
Old 02-15-2004, 05:37 PM   #4
if the valves need adjustment it should sound like a ticking noise coming from the engine. marbles rattling almost suggests detonation, which i doubt that it is, but check the ignition timing just incase.
Old 02-15-2004, 05:43 PM   #5
Shaved &/or Laid
Shaved &/or Laid's Avatar
detonation rules.
if you let it keep doing that, youll bend a rod twice and tear up a crank and a piston and a bearing, as well as holes in cylinder wall and block !
get that shit looked at IMMEDIATELY
Doody Ej1
Yse.
Old 02-15-2004, 05:50 PM   #6
allglock
Can you explain detonation?
Old 02-15-2004, 07:13 PM   #7
allglock
No its NOT pinging or detonation. I meant it had a marbly sound revving it in park.
Old 02-15-2004, 07:17 PM   #8
vtracer20
it could be the same sound ihave in my accord....but it's deff not the valves or w/e, i think it's because i bought my accord at 98k and i have no idea what's it been through....i think accords are prone to get their rods bent in a little, i believe that's correct, i'm sure someone will prove me wrong. That's my noise
Old 02-16-2004, 02:16 AM   #9
"marbles" sounds a LOT like detonation to me
Like bb's/marbles in a tin can? Popcorn in a microwave?
Old 02-18-2004, 01:37 PM   #10
Honda_Tengoku
spun rod bearing
Old 02-18-2004, 01:40 PM   #11
Honda_Tengoku
BTW u can use a piece of wood (like a 2 foot 2 by 4 or something) or a metal rod and put it up against the block at certain points. Put your ear on the other end and listen. Its an an old easy way to tell where the noise is coming from. U would be suprised what u can hear.
Old 02-18-2004, 02:57 PM   #12
LMAO. that old trick, i thought it was lost in the age of the diagnostic computers and stuff.
Old 02-18-2004, 02:58 PM   #13
Ive used a big ass screwdriver before
Old 02-18-2004, 11:16 PM   #14
Kyle
elyK
the deaf guy in "mr. hollands opus" used a screw driver...
IGNORE THE FACTS
EXPLORE THE TRUTH
Old 02-19-2004, 12:29 AM   #15
i tried to watch that movie once
Old 02-19-2004, 07:34 AM   #16
allglock
Had valves adjusted still has tapping noise...........................
Can solid lifters go bad?
Old 02-19-2004, 10:46 AM   #17
...there are no lifters.
There are, however, followers. Unfortunately, if they were bad, and you went to a good shop, they would have told you that (thats if you had it done).
I STILL say detonation.
What do your plugs look like? What gas octane are you using?
Old 02-19-2004, 01:38 PM   #18
Honda_Tengoku
u dont have lifters. No such thing on a Honda. A worn out valvetrain can be the other culprit on a high mileage engine.
Old 02-19-2004, 01:39 PM   #19
Honda_Tengoku
why not use it if it works?
Old 02-19-2004, 01:49 PM   #20
i still use it. it's just i was amazed someone else besides me uses it
Old 02-19-2004, 04:50 PM   #21
spun rod bearing
"Also does it make sense that it gets alot quieter as it warms up"
Old 02-20-2004, 02:23 PM   #22
Honda_Tengoku
well perhaps not. It maybe he is thinking it is but he may just be getting used to the sound. Who knows. He really needs to do more troubleshooting and pin point the problem a bit. There are just too many variables right now.
Old 02-25-2004, 10:21 AM   #23
allglock
Anyone know of any other Honda forums out there? I would really like to get an answer to this. For a 46K mileage car, this thing should be quiet.
Old 02-25-2004, 11:18 AM   #24
youre not being specific enough...youre just saying "my car makes a noise"
try honda-tech.com
Old 02-25-2004, 11:22 AM   #25
who adjusted it for you ? if you did did u use an offset feeler gauge ? was the mark on the cam gear at the required positions ? i know for sure that doing it without an offset gauge it's pure lottery. the first time i did it it came out sweet, the second time came out like shit and my engine knocks even worse that before. is the hollow noice inside the cabin ? or is it when the hood is raised and you are in front of the car. so many knocks can come out of an engine it's not even funny
