Old 02-14-2004, 04:31 PM   #1
Ezra
H23 Vtec setup
First of hello to everyone as i'm new to this forum and hope i will be of help to some as some will be of help to me...
Now on to the questions....
Im working on my younger brothers Prelude, a 96 Si h23a1 automatic and the ecu code reading is done via OBD2. However I looked under the floor mat at his ecu and found this little thing...37820-p14-a63-894102616. This P14 is supposed to be an OBD1 ecu but not in this case.... anyone know why? the car was manufactured in japan june 96 and what i wanted to do was keep it all obd2. I bought a P5M ecu from a 98 auto lude and was hopping to be able to just plug it in and run a vtec wire but now im not so sure... Any one know if in 96 honda made an obd2 P14? Also can anyone point me in the direction of some ecu skematics for the 96 and 98 ludes?
Thanks...
The engine plan is h23 bottom, .25mm over type S pistons (11:1) h22 vtec head with a golden Eagle intake manifold, mustang 70mm tb, ractive 4:2:1 exhaust and some porting and polishing of the head done by me... I am planning on using the h23's dist on the h22 head and add a vtec oil pump and run a feed line to the head... you guys see anything i'm missing?
Ezra-
