Old 01-30-2004, 01:26 AM   #1
Aquariust
D15 vs D16 Bottom End Differences
OK all, I have a d15b2 which In plan to modify. I've bought a si trans, mpfi swap, port and polished d16 head, stage 2 cam, adj cam gear, block guard, and a t25 turbo setup. The only weak link I see is the bottom end. It has a good 110K on it, and I've beat it pretty hard the last few thousand
I'll try and number the ?'s to make it easier to answer the ?'s you know.
1)Can anyone tell me some of the differences with d16a6 block compared to my d15b2? 2)Does it have a different crankshaft? 3)Different Pistons? 4)Do the pistons from the zc or d16a6 fit in the d15b2 block? 5)Is the wall thickness the same?
What I really want to know is can I just drop integra ls rods and si or zc pistons into my d15 and be fine with hp and boost I'll be making (8psi or so).
Otherwise, I'm going to have to look for a d16 block also.
Any help is greatly appreciated!
-John
