Old 01-28-2004, 02:57 PM   #1
chefmaster21
no washer
having no washer nozzles in the winter sux. i have a cf hood didn't come with pre drilled holes so now i have about an inch thick of salt on my winshiled boo boo boo
chefmaster21 is offline   Reply With Quote
Old 01-28-2004, 03:08 PM   #2
Install the nozzles?
Old 01-28-2004, 03:29 PM   #3
chefmaster21
never got around to it and don't trust anyone to drill the holes
Old 01-28-2004, 03:33 PM   #4
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
well if your not gonna do it, quit yer complainin'!! hehe.. or buy a box of rain-x
RICE....is good
Old 01-28-2004, 03:38 PM   #5
Fatal070
Fatal070's Avatar
right right ...right, i feel yeah
Old 01-28-2004, 04:28 PM   #6
Drill them yourself?
Old 01-28-2004, 04:42 PM   #7
4drmadness
shit I removed my washer fluid box along time ago..
now I got a CF hood and still no nozzles...I have purchaed stock in rain X and Black rain for my windshield and that works wonders in the rain and beads it right off...ohhh yeah
Old 01-28-2004, 05:14 PM   #8
chefmaster21
i was thinking about putting my stock hood back on for the winter. then i don't want my cf hood getting messed up no space
Old 01-28-2004, 05:38 PM   #9
MAXed Out
6th Gear
MAXed Out's Avatar
Some cars have them underneeth the hood like my integra there are no holes to
be drilled so u can do it that way with out damaging ur cf hood.
SHIFT_MyNuts
Old 01-28-2004, 05:55 PM   #10
just get a new drill bit and have at it
or a dremel w/ cutting wheel
look at it this way:
If you take it somewhere and they screw it up, they need to replace the hood. Simple as that. If you do it and you kill it, youre SOL
Old 01-28-2004, 06:07 PM   #11
MAXed Out
6th Gear
MAXed Out's Avatar
it wold still mess the hood up and it will loose it's clean look it u drill holes in it.
SHIFT_MyNuts
Old 01-28-2004, 07:13 PM   #12
DO NOT DRILL THE HOOD
you will regret it. the nozzels look retarted on a cf hood imo. i never had nozzels in my hood, but i rigged the line to spray a stream of water on the windshield from under the hood for in the summer when it rains and water spots dry on the glass
Old 01-28-2004, 07:20 PM   #13
mount the nozzles to that plastic cover underneath the windshield
Old 01-28-2004, 07:29 PM   #14
i tried that, didnt work good at all. the nozzles have very little play as to what direction they point in. you'd have to make some sort of bracket so you can get a good angle and still be able to run the line for water under the cover
Old 01-28-2004, 07:39 PM   #15
well you can wind the lines for $2 at every autoparts store
Old 01-28-2004, 08:23 PM   #16
chefmaster21
yeah i deffinalty wasn't even thinking about drilling holes cause i knew it would take away from the clean smooth look of the hood and i didn't want to mess it up and pretty much know it will, if i did drill them
Old 01-28-2004, 11:28 PM   #17
sohc_vtec 2NR
so do you have hood pins on the cf hood? cuz if you do then the smooth clean look is no longer there so might as well drill the nossle hole...if you don't have hood pins then i wish you luck that it doesn't fly off
RICE....is good
Old 01-30-2004, 04:27 PM   #18
chefmaster21
no hood pins. i have had my hood for a little over a year and have not had a problem with not using pins
Old 01-30-2004, 04:47 PM   #19
edit\ fiber image hoods dont need em
Old 02-01-2004, 12:14 AM   #20
C's 94 InTeGrA
C's 94 InTeGrA's Avatar
mine dont work on my beater car.. my cutlass.. thers a leak somewhere in the line cause everytime i fill up it and try to use them its all gone!!
Old 02-01-2004, 11:40 PM   #21
chefmaster21
in the winter i have found the best way to clean my winshield is take a wet paper towel and wipe window then take dry paper towel and dry it. everything else freezes like glass cleaner. but my boy friend knows how much it is drving me crazy hes gonna rig something up this weekend for me hopefuly he can figure something out
