Old 01-25-2004, 06:50 PM   #1
cegleitz
Ecu Location!!!
Where is the plug to check the codes on a 96-00 civic?
Old 01-25-2004, 06:57 PM   #2
take off passeneger side kick panel..
find 2 wire plug that is not plugged into anything..
take off dust cover..
put a jumper or wire (or paperclip) to connect each of the terminals
turn key to on position
count the flashes
1 long flash = 10
1 short flash = 1
add it up
so long long short short short = 23
Old 01-25-2004, 09:57 PM   #3
chefmaster21
its on the drivers side right next to the fuse box you can't miss it
chefmaster21 is offline   Reply With Quote
Old 01-25-2004, 10:01 PM   #4
thats the diagnostic port for an obd reader
he wants the service connector for pulling codes
Old 01-25-2004, 10:11 PM   #5
4drmadness
Pass kick panel is the spot indeed....good luck and hope you get the code to fix what you need..
Old 01-25-2004, 10:56 PM   #6
first off what do you think is broke?
Old 01-25-2004, 11:02 PM   #7
It's a blue clip with 2 wires
....and welcome to HST
Old 01-26-2004, 08:10 AM   #8
do the obd2 cars have the same ? i thought the obd2 codes were something weird with letters and numbers
Old 02-01-2004, 12:00 AM   #9
It's about the same......
Old 02-01-2004, 02:29 AM   #10
that's good to know. i think i gotta read some more on hondata
