Old 12-21-2001, 12:13 PM   #1
twoglude
driveshaft noises/wheelbearings?
i have this wierd sound coming from the front end. i know my shafts are in need of repair, but this sound is harder than a bad cv joint. it only happens at low speed, during sharp corners. it is more of a clunk, grinding sound.
does anyone here no what it could be? what does a bad wheel bearing sound like?
its not as soft sounding as the cv joints.
any help is good help. THANX
Old 12-28-2001, 04:31 PM   #2
Hello fellow Canadian!
When you get sounds at low speed, cornering.. bla bla
It's probably time to replace the bearings.. The balls are probably all crushed.
Old 12-28-2001, 07:38 PM   #3
change those damn bearings and it will go away. I had it on my accord and they dissapeared after a while, but i'm expecting them soon.
Old 01-02-2002, 02:31 PM   #4
twoglude
thanx guys. i will do the shafts for sure and most likely the bearings too.
i have heard that you have to get the bearings pressed in. is this true?
Old 01-04-2002, 11:01 AM   #5
Yep it's true.
