Old 12-29-2003, 12:11 PM   #1
muhf41
Help With Vtec Not Working
What up? I swapped a 97 H22 into my 90 accord and everything is fine with the motor and swap except for VTEC. I cant get it to work. I have tried to pin it to the ECU in A4, re wired the run from the soleniod twice and still no go. Any ideas from anyone? Anyone had this problem? Either I am a dummy or something is wrong. I put the ECU in my friends car that has the same setup and it works in his car so I know it is not the ecu. Is that pin connection touchy? Could it be that it is not getting a full connection and if it is not any suggestions? Anything you guys could suggest would be much appreciated. Thanks all!
Old 12-30-2003, 09:04 AM   #2
gerhard
Parked
Have you tested the solenoid to ensure it's actually working?
Also, your engine isn't low on oil is it?
Lack of proper oil pressure will cause the engine to not engage in VTEC operation.
gerhard is offline   Reply With Quote
Old 12-30-2003, 12:24 PM   #3
muhf41
I have checked the soleniod, gave it some juice and got some activity out of it so I am 99% sure it is functioning. There is only 250 miles on my swap so I am 99% sure that the oil pressure is not the issue either. I am throwing code for my TPS sensor so when I get that dialed in and get that code to go away, do you think that will have impact? Thanks for your insight.
Old 12-30-2003, 12:27 PM   #4
gerhard
Parked
The TPS code may prevent the VTEC from working...
Throttle position will effect the VTEC.
Old 01-05-2004, 04:34 PM   #5
vtectuned
did you check if it's getting a signal?
Old 01-05-2004, 05:33 PM   #6
muhf41
I have not checked or worked on the car yet because it is 1 degree outside in Colorado. No knuckle bustin here. Soon. Thanks to all for the help.
Old 02-06-2004, 12:37 PM   #7
muhf41
It was TPS and all codes went away, all should be fine now, thanks for your help guys!
