Old 12-15-2003, 08:26 PM   #1
BlackCivic
Honda Civic IAC
Hey guys I need help. My idle is going up and down. I know its the IAC. But wanted to know wich site sell them. And how much do they go for. I think on the honda civic there are two Idle Air Control Valves. Please I need all the help.
Old 12-15-2003, 08:53 PM   #2
have you cleaned it yet?
what about just adjusting the idle control valve?
have you messed with the coolant recently?
Old 12-15-2003, 09:23 PM   #3
clean it!
Old 12-15-2003, 11:32 PM   #4
try cleaning it frist. then if it still happens then buy new ones.
Old 12-16-2003, 04:35 PM   #5
Check your coolant... it's probobly low in the radiator...
otherwise... clean the iacv... it's pretty easy... just a few 10mm bolts holding it on... take them off don't even have to remove the coolant lines (if you do be carefull as they're pressurized) spray out the little holes with carb/choke cleaner...
That's what I did... worked just fine.
Old 12-16-2003, 08:20 PM   #6
BlackCivic
Where exactly are they located? In know its on the intake manifold. But where. And is there really two IAC?
Old 12-16-2003, 09:47 PM   #7
Old 12-16-2003, 09:48 PM   #8
wow thats big!
oh in the first pic the big round thing on the right is the throttle body. your looking at the intake manifold from behind.
Old 12-16-2003, 09:53 PM   #9
indeed
Old 12-17-2003, 10:01 PM   #10
Like they said clean it first. Sand, dirt & such can get in there.
Otherwise you need to get that from a dealer. I had mine replaced on the Si for the same issues you're having. USE WATER TO CLEAN IT. Don't use any chemicals.
Old 12-17-2003, 10:51 PM   #11
i used throttle body cleaner, i didnt have any problems.
what makes you suggest water? especially since water isnt very good as a cleaning agent.
Old 12-17-2003, 11:16 PM   #12
ive used carb cleaner
Old 12-18-2003, 07:36 PM   #13
BlackCivic
Do you guys know how to adjust the throttle cable as well?
By the way thank you all for all the help.
Old 12-18-2003, 08:12 PM   #14
if you take a look at where the calbe attaches there are 2 nuts that keep the cable taught against a retainer (just looks like a fork w/ 2 prongs)
just pull it kinda tight (not to where the tb opens) and tighen the nuts together
