Old 12-07-2003, 07:26 PM   #1
Fatal070
Fatal070's Avatar
where is the vin located on a b18c1
Old 12-07-2003, 07:35 PM   #2
It should be on the bottom end/long block, in the vicinity of the B18C stamp. That is where mine is.......
Old 12-07-2003, 07:42 PM   #3
at the bottom on the long block
Old 12-07-2003, 08:46 PM   #4
its on a green tag
Old 12-07-2003, 09:19 PM   #5
Fatal070
Fatal070's Avatar
thanks guys and thanks for not being assholes , i did remember about the codes and it def has a 170hp thats what i was worried about it will be done soon im very exited sad they f'd about the year but the obd1 is better ive heard so im not that sad hey do u guys have aim?
Old 12-07-2003, 09:53 PM   #6
OBD1 is better but it is going to be work to get an obd1 motor to run in an obd2 car (wiring issues)
Im not a swapping pro...so Im probably not the one you wanna talk to...
but yes, I do have aim and its pdiggitydogg is my user name for that as well
edit**found this...might help
http://www.hondata.com/techwiringgsr.html
Old 12-07-2003, 11:31 PM   #7
do you have state/city vehicle inspections?
Old 12-08-2003, 12:56 AM   #8
~ Title edited by BDC ~
Old 12-08-2003, 07:23 AM   #9
cashizslick
Wow, BDC posts out of nowhere!
If you have state inspections - you could get in trouble because it is "illegal" to put a motor in your car that is older than your car. .
Old 12-08-2003, 09:53 AM   #10
last i heard you couldnt put a motor in your newer then yours.
example: 93 civic put a 93 Integra motor works state cant do anything.
93 civic 94 integra motor. illegal. impounded and fined out the ass.
me i dont care. here in iowa they dont inspect cars. they dont even give out tickets when they break up the races.
Old 12-08-2003, 12:15 PM   #11
nah it is older engines that are illegal to drop in
new ones are ok
