Old 11-24-2003, 02:25 PM   #1
Shaved &/or Laid
Shaved &/or Laid's Avatar
more than popping in MY exhaust
for some reason, it seems liek i have ****ed up my exhaust terribly. it rattles troughout hte hwole powerband following hte swap. I dont understand, i even had my HUGE dad tighten my exhaust bolts ultra tight on the cat. What else could it be ? i basically unhooked a lot to get to the shift linkage, and didnt put all the hookups to the car back on. that my problem ? also, would a bent heat shield do that ? it sounds like its falling off.
Doody Ej1
Yse.
Old 11-24-2003, 02:53 PM   #2
prob heat shields
Old 11-24-2003, 03:57 PM   #3
Re: more than popping in MY exhaust
are you talking about the exhaust hangers!?
Old 11-24-2003, 04:12 PM   #4
cashizslick
buy a new exhaust shave.
check to make sure all the hangers are in properly like az said, then make sure your heatshield isnt rattling, it it is, then thats ur problem.
Old 11-24-2003, 04:45 PM   #5
you should be able to shake the exhaust from underneith it and locate where it's banging...
Then try using a prybar to get it to sit in a position that doesn't make it bang... usually you'll have to bend a hanger or two or lossen all the connection points... then re-align it and tighten them from front to back...
But like has been mentioned... If you didn't re-install all the hangers.. YES that will cause it to vibrate much more than it should.
Old 11-24-2003, 05:59 PM   #6
on my brother's teg it rattles like that because it hits the rear swaybar, just because the car sits so low.
Old 11-24-2003, 11:52 PM   #7
yeah, my exhaust hits the swaybar too, and its not even lowered. but yeah it could be a combination of missing hangers, heatshield rattle, toasted cat, and poor engineering of the piping itself. I personally went to hobby lobby and bought a big bag of leather scraps, and wrapped them around the problem areas (secured with big hose clamps). it helps immensely.
Old 11-25-2003, 10:34 AM   #8
Ive seen people do similar w/ old shoes
Old 11-25-2003, 11:54 AM   #9
cashizslick
Ya, and shaves car is real low . . . . . . . . . .
Maybe you should get ur car up on a lift to check everything out.
Old 11-25-2003, 11:46 PM   #10
Shaved &/or Laid
hm. i know i left one of the hangers by the shiftlinkage undone. and bend the heatshields a lot. ill have a look-see.
Doody Ej1
Yse.
Old 11-26-2003, 03:29 PM   #11
Does your shifter shake too? nonov beat me to it. Shake it and see where it's coming from. The engine doesnt have to be running.....
Old 11-27-2003, 12:27 PM   #12
Shaved &/or Laid
well my shifter does move, but only because my rear motor mount is bolted up. imma fix that today. that mount is an asshole.
Doody Ej1
Yse.
