Old 11-20-2003, 09:56 PM   #1
Crix
Need info on new valves for B16a.
I have my B16 head at the machine shop and want to know if getting aftermarket valves is worth it and if so what kind and where to buy. I am having the head port matched and bowl cut and Skunk2 Valve train. My setup will be Crower stage II cams 440 injectors I/H/E, ITR manifold and V-AFC. I am going to be using a mugen head gasket to boost compression by .2. Also FPR and fuel rail. And yes I want to go fast.
Old 11-20-2003, 11:08 PM   #2
I wouldn't waste the money. Get your existing valves re-worked with a 3-angle and call it good. If you feel the need, Ferrea makes a good valve.
