Old 11-01-2003, 12:12 PM   #1
LaNRoVeR
Honda Maintence
Well,
I was woundering when certain things should be looked at upon increasing milage on the car.
Old 11-01-2003, 01:34 PM   #2
timing belt
water pump
valve adjustment
fluid check ups
those are the most important basic things imo
other things like wheel and tire balance, alignment, rotation, etc should be taken care of as well...but are easier to notice because you see them
Old 11-03-2003, 12:51 AM   #3
ignition systems on hondas seem to go pretty easily also.
also, check your cv boots, seems like every car ive bought or dealt with has at least one ripped.
fluids to watch are:
Engine Oil
Trans oil (gear oil for manuals, ATF fluid for autos(done by machine))
Power steering fluid (about 80 bucks for flush and fill)
Coolant (good idea to have the system flushed, not just topped off)
Brake Fluid (just watch the levels from outside the resevoir. you open it youll prolly contaminate it)
Old 11-03-2003, 01:05 PM   #4
jamez18
Also
all rubber hoses
battery- make sure there is no corrosion
jamez18 is offline   Reply With Quote
Old 11-04-2003, 04:42 PM   #5
Shot 2 Hel
spark plugs
Old 11-07-2003, 12:15 AM   #6
thud
Change the oil before your engine oil light comes on.
Old 11-07-2003, 08:25 AM   #7
LaNRoVeR
Well I know about the fluids
I know about checking up on your fluids thats common sense. I was just woundering about the internals that I need to be checking up on. Thanks for the replys guys!
Old 11-07-2003, 11:11 AM   #8
do a compression check.
Old 11-07-2003, 01:05 PM   #9
armyguy5
3rd Gear
armyguy5's Avatar
and dont forget the valve adjustment as stated by Pdiggity
chris
Old 11-07-2003, 01:59 PM   #10
incase you didnt know, the way to tell if your over due for a valve adjustment is theres a weird ticking coming from the engine.
Old 11-08-2003, 07:28 PM   #11
Shaved &/or Laid
Shaved &/or Laid's Avatar
when its idling, and youre outside the car is when its easiest to tell.
Doody Ej1
Yse.
