Old 10-27-2003, 10:38 PM   #1
Dx - Ex
ok guys need some information on this swap.
what exactly needs to be changed. i know the motor and ecu. but what else? is there really any difference between the to beside HP and ecu.
this isnt ben, its his friend jason.
(i havent got my own comp so i cant registar.)
Old 10-27-2003, 11:53 PM   #2
armyguy5
3rd Gear
armyguy5's Avatar
i believe iu can just do a head swap and get a Vtec head but i'm not sure about the 93
chris
Old 10-28-2003, 01:50 AM   #3
Shaved &/or Laid
Shaved &/or Laid's Avatar
yeah. im selling mine maybe.
Doody Ej1
Yse.
Old 10-28-2003, 02:09 AM   #4
It should be a straight shot with the exception of those already mentioned.
Old 10-28-2003, 09:42 AM   #5
so just swapping the head would do it? i get 125HP instead of 109? what about my torque?Would it also gian some?
if i do the head swap do i still have to change the ecu?
Old 10-28-2003, 10:12 AM   #6
is it really worth it for 14hp gain ? maybe i would go with a b series, or if you plan on building up this one. as for the dx-lx what differences are you talking about ? just the engines ? i know they have different engines, but also there are some trim differences like power locks, power windows and AC.
Old 10-28-2003, 12:17 PM   #7
armyguy5
3rd Gear
armyguy5's Avatar
no you wont have to change the ECU...
chris
Old 10-28-2003, 05:11 PM   #8
^... YES you would need to change the ecu... otherwise vtec won't ever engage... it's computer controlled.
I wouldn't bother doing a headswap... swapping the whole engine/tranny (if you already have them) would be easier...
As far as this not being worth it (hondamaniac)... You'd be a fool to spend more than 600 bucks for a full z6 engine/tranny... so comparing it to a b swap (1500-4000) is kinda out of line...
A sohc vtec engine has more than enough potential and it would be a SIGNIFICANT increase in overall power for someone used to dx power...
I'd say just do the whole swap and save the old block for just in-cases'...
Also the reason I wouldn't recomend swaping heads is...
A. You will not make the same power with a dx bottom end and ex top...
B. The d16z6 has piston squirters (to cool pistons)
C. To properly swap the head you should have both it and the block decked... which in itself is more trouble than it's worth.
D. Even though it's more work swapping the ex and it's harness/ecu in would come out much better and be more reliable than a mini-me head swap.
just my opinion.
Old 10-28-2003, 11:49 PM   #9
ok well i got an engine and im using my dx man tranny till i get somemore money for a ex. can i use stock mounts axels ect ect.
i need a parts list of what i need.
i dont need interior mods.
Old 10-30-2003, 01:48 PM   #10
do you guys now were jason may be able to get a wiring harness and ecu cheap? thanks
Old 10-30-2003, 02:07 PM   #11
what harness and what ecu
what for
Old 10-30-2003, 02:11 PM   #12
For an EX Vtec Engine D series.
Old 10-30-2003, 02:24 PM   #13
oc civic
get one at the junk yard.. thats where i would look
Old 10-30-2003, 03:38 PM   #14
good idea, we check 2 a week or so ago and came up empty handed. well check more and recheck the one we already did.
