Old 10-23-2003, 01:06 PM   #1
Caliprophet
Neon Lights
Any one hook Neon lights the small ones directly up to the battery with a fuse. I want to hook three of them up with one fuse and run them to a toggle switch on my dash, I have two spots left next to my fogs. Just wondering if the power will be too much to cut the wires from the ciggarette lighter adapter and run it through the battery.
-caliprophet-
Old 10-23-2003, 10:02 PM   #2
4g63t
Why dont you just hook up your switch to the acc. place in the fuse box. Then hook up your power lead from your neons onto the toggle? Just an idea though. But to answer your question. If your battery is 12v then why would you need a resistor to hook up a 12v lead???
Woohoo, top speed 145 at 6k rpm.
4g63t is offline   Reply With Quote
Old 10-24-2003, 11:03 AM   #3
Caliprophet
Good point
I will try to run it throuh the fuse box then I wont have to worry about running a wire through the firewall.. Thanks
-caliprophet-
