Old 10-22-2003, 02:47 PM   #1
88CrxnCa
Help on powering up my crx
I have an 88 Crx hf with a Zc swap. I have intake and exhaust so far, plus a dual stage clutch. What more can i do to this motor with a low budget???
Old 10-23-2003, 12:41 AM   #2
have you built the motor at all? or was it just a swap n go? you could run low boost and be okay, but if you want to make much more power you need to rework the internals, and seriously build the bottom end.
you could always go nitrous, but if you dont go to the track, whats the point?
it all depends on what you want to ultimatly do. If your okay on the engine side of things, focus on other things. suspension to make it handle better, improve your braking system (get rid of the rear drums, go to disc)
Old 10-23-2003, 03:16 PM   #3
88CrxnCa
Well see i dont really have too much money and i don't want to go for show, the suspension is pretty crappy right now, so what would you suggest as a decsent setup to go with for a lower price??
Old 10-23-2003, 08:58 PM   #4
progress springs/kyb agx struts. cheap-good.
