Old 10-08-2003, 10:35 PM   #1
Shaved &/or Laid
Shaved &/or Laid's Avatar
Hubs removed, how to get axle out ?
Axle is freed, now how do i get it out of the tranny ? Just pull it really hard ?
Doody Ej1
Yse.
Old 10-08-2003, 10:47 PM   #2
no dude...remember? Pry
use a big-ass screwdriver or a breaker bar (theyre small crowbars, if ya dont know)
this pic theyre using a ball-joint splitter (which would work...but Id use the breaker bar)
Old 10-08-2003, 10:52 PM   #3
Shaved &/or Laid
allllllright. I used a ball joint splitter...ON THE BALL JOINTS lol
but if it works onteh axlessorxx then thats great. Id just rather not be under the car prying as hard as possible with it on jack stands, so i figured pulling REALLY hard might work
Doody Ej1
Yse.
Old 10-08-2003, 10:58 PM   #4
no no...see jerking on it you run the risk of the car coming off the stands...and you wouldnt get it off anyways
run (not literally) down your local hardware store and get a pry/breaker bar...they serve lots of purposes...well worth theyre small price)
slide the end in there and pry...not jerk it around...easy. you'll be fine as long as ya dont move around like a maniac
Old 10-08-2003, 11:39 PM   #5
why are you pulling the tranny out? just wondering
Old 10-08-2003, 11:39 PM   #6
Shaved &/or Laid
hehe yeah we got them around. I call them prybars.
I thought breaker bars are the hugeass ratchet looking ones that i used to get my 32mm's off.
I got my 300lb dad so stand on it. Would that be 300lbs/ft of torque to get that ***** off ? he was about a foot from the bolt when he stood and jumped on it lol.
Doody Ej1
Yse.
Old 10-08-2003, 11:48 PM   #7
different area, different names i guess
a ft away? nah that wouldnt work.....3ft should...as long as it doesnt slip off
Old 10-08-2003, 11:51 PM   #8
Shaved &/or Laid
oh it worked. Dad is ENOURMOUSLY big. Hes proud to contribute dont think the bolt was happy though. Looks kinda jacked up now
Doody Ej1
Yse.
Old 10-09-2003, 12:11 AM   #9
it worked?!
a little unorthodox...but as long as it worked and ya didnt break anything vital...cheers
Old 10-09-2003, 08:32 AM   #10
i just pry my axles off. and to take out the 32mm nuts out i use an impact wrench and if that does not work i use a 10ft piece of pipe with my tq wrench.
Old 10-11-2003, 12:00 AM   #11
Shaved &/or Laid
i gots it off.
i took a Balljoint splitter to that Sum-***** and it was easy as all hell. Deezamn.
Im taking it out cause im mswapping El b16 in. Maximum sexitude.
Doody Ej1
Yse.
