Old 10-04-2003, 04:03 PM   #1
drdingo21
drdingo21's Avatar
Uggh, car is bogging
I don't know what the hell the problem is, but when ever i floor it and rpms are under 3k, then the car bogs for a second and then just goes like normal. What the hell is the problem? Anyone have any ideas?
Old 10-04-2003, 04:30 PM   #2
hooohaa2
downshift
Old 10-04-2003, 04:30 PM   #3
MAXed Out
6th Gear
MAXed Out's Avatar
do a tune-up.
SHIFT_MyNuts
Old 10-04-2003, 04:58 PM   #4
drdingo21
drdingo21's Avatar
hooohaa2 , don't waste my time with posts like that..
I was debating about the tune up. But i was wondering why it did that. I was thinking something with fuel delivery.
Old 10-04-2003, 06:13 PM   #5
it may be an ignition problem. faulty plug/wire.
Old 10-04-2003, 10:44 PM   #6
hooohaa2
I have run into a timing problem with similar symptoms. I can't remember if I advanced or retarded timing, but that was the problem (might not be the same in your case, this was pretty severe bogging, then running like the dickens). I think I had to advance the timing.
replace your fuel/air filters.
Old 10-05-2003, 09:06 AM   #7
You would have advanced the timing.. doubt its a filter issue though..
Old 10-05-2003, 10:10 AM   #8
i think it's a timing issue, or a valve adjustament. after i did my valve adjustament the car came back to normal.
and if you plan on modfying the igniton timing setting you need to advance it, not retard it.
Old 10-05-2003, 07:26 PM   #9
id check for a fouled plug first...then the fuel filter
after those Id take it in for a checkup...may be in need of a valve adj.
Old 10-09-2003, 07:45 AM   #10
nosaj81_2000
maybe your flooding the throttle when you floor it and the fuel delivery tries to catch up with the preasure it dumps too much fuel into the intake which in turn would call for a tune up (i think)
Old 10-09-2003, 09:04 AM   #11
drdingo21
drdingo21's Avatar
thanks guys but i got it. I did half of a tune up. Replaced all the plugs, air filter (it needed it) and the oil. There were two plugs that were gapped at 54 thousands of an inch instead of the 44 thousands they were supposed to be. Now all is well.
Old 10-23-2003, 11:24 AM   #12
jaberg00
Hey what the hell is your problem come onit your car so u supposed to know whats wrong with it, any way your car has a cold, sike all those opinion that they gave you, it could be any one but do the tune up first then u can check the rest.
Old 10-23-2003, 11:59 AM   #13
drdingo21
drdingo21's Avatar
Not to be a dick but....
wow. I have a headach from trying to understand that post... And if you read my post i fixed the problem.
Oh and BTW
Old 10-24-2003, 09:51 AM   #14
i like your BTW Dingo. awesome as hell.
Old 10-24-2003, 09:56 AM   #15
drdingo21
drdingo21's Avatar
thanks ive been waiting to use those pics
