Old 10-03-2003, 03:47 PM   #1
MAXed Out
6th Gear
MAXed Out's Avatar
Water Cooling!
Who here has water cooling on your pc? Cause when i got my pc built i was considering it but kinda forgot about it but now my pc is on 24/7 and it gets up to 49*C/120*F and it's not bad but it can be colder. So let me know how hard it is to do and how much it cost you.
SHIFT_MyNuts
Old 10-05-2003, 06:08 PM   #2
how much colder do you want it?
what mobo do you have?
you might be able to spend less and get yourself a thermalright slk-800 or slk-900 with a nice fan and some sort of fan controller.
Old 10-05-2003, 06:11 PM   #3
I was using watercooling, but I'm not ATM. Its pretty easy, and I went with a custom setup. The pre-builts generally suck. Its easier if you have a mobo with mounting holes BTW, but there are work-a-rounds.
49* is just fine if your PC is stable. I wouldn't even worry about it. If you are just looking for slightly lower temps, I've had good success with SLK-800s and 900us. The 900 will be quieter if you use a 92mm fan.
