Old 10-02-2003, 11:24 PM   #1
Internet works only thru a proxy
Hi,
The problem is that I'm unable to access the internet. Everything was fine yesterday, and this morning it was dead.
I didnt install anything in particular.
I dont have any virus/trojan horses/worms/malware/etc..
When I enter a proxy in the Connection settings, the net works (IE, streaming media)! Outlook, ftp & direct connect do not work. And KAZAA works with OR without the proxy enabled..
A few days ago I downloaded the Speed Guide TCPOptimizer and I've switching between the "current settings" and "Optimal settings", regardless of that everything was fine for till today.. I didnt play with the individual settings..
Any suggestions?
thanks,
JP
Old 10-02-2003, 11:42 PM   #2
Hrm... Are you connected directly to the net (or through a router), or are you using another gateway machine?
I find it odd that you would go to bed and have it stop working, which makes me think it might not be your fault. Have you called the ISP? I'm wondering if its a setup problem on their end.
Old 10-02-2003, 11:47 PM   #3
I am behind a router.. However the other PC on the LAN is working fine.. I doubt its on the ISP's end since the other PC is fine..
Is there a way to flash all the internet settings or bring them back to the default settings?? Not just the reset buttong on the Advanced tab in IE options.. tried that one already..
Old 10-02-2003, 11:51 PM   #4
I don't know of a way to do that unless you do a system restore (I think that would do it). Yeah, obviously not the ISP then.
Do you have some more info on the optimizer you used? I doubt that's a problem since you've been using it though.
If I was having the problem, I'd start by looking at all of the network settings. Make sure DHCP is on (assuming you use it), privacy setting are set to let all traffic through, router settings are normal. I know its a pain though. Maybe someone else will have some suggestions.
Old 10-02-2003, 11:57 PM   #5
THe optimizer is the one from Sped Guide (speedguide.net), but like you said, its probably not causing the prob..
Anyways I'll keep going for a while..
thanks for the suggestions!
Old 10-03-2003, 12:39 AM   #6
I fixed it!
I uninstalled the current tcp/ip and reinstalled it.. all is well!
Old 10-03-2003, 01:12 AM   #7
Originally posted by Accord Man
I fixed it!
Glad to hear it JP! That makes me think that program did somehow affect it because it modifies the stack settings. Strange either way, but at least it works now.
Old 10-03-2003, 09:31 AM   #8
my guess is that the proxy made a poo. it happened on my laptop befeore. i just set the connection thru a lan, not thru a proxy. Also if kazaa worked fine i don't think the problem was the tcp/ip. i think it was more of a binding issue. :o
Old 10-03-2003, 01:06 PM   #9
pbateson
The reason of problem on my computer were not work happened 2 days ago. I didn't go thru the internet yesterday when I got home from school.
Old 12-11-2003, 12:50 AM   #10
i have the same problem right now only with IE. all the otehr programs are working just fine. any ideas ? i got a bunch of spyware today and after i removed it the ie won't load any pages.
Old 12-11-2003, 01:34 AM   #11
Reinstall IE
Old 12-11-2003, 02:06 AM   #12
HOW ? I tried removing it and i can't, i tried installing it and goes with the same settings. I removed tcp/ ip and tried to reinstall it and the whole thing went down the drain. it's been 4 hrs since i was working on it
Old 12-11-2003, 02:21 AM   #13
Hmm.... I'm not sure. Don't mess with TCP/IP if your other browser works.
Look in your spyware program and see if it has an undo function.
Reinstall Windows
Old 12-12-2003, 06:34 AM   #14
heh, i reinstalled windows and my net card took a crap, so i did wipe the hard drive. lost about 2gb worth of mp3's and my bank statements for the past year or so.
Old 12-13-2003, 06:10 PM   #15
Stef, when you cleaned the spyware out of your computer, did you quarantine it or completely delete it??
Most progs quarantine the files.. So you'd only need to restore..
How about a windows repair??
Old 12-13-2003, 06:11 PM   #16
umm, too late..
