Old 09-29-2003, 07:18 PM   #1
CivicSlug
CivicSlug's Avatar
need some serious opinions!
I've got a bad rod. Its about to go, need too....
1) Get engine rebuilt
2) Buy a replacement/rebuilt engine of the same kind
3) Buy a Civic Type R JMD spec engine
These are my options as I see it.
Before anyone starts talking about engine swaps, STOP!! I need to do this on a budget, and I want to be able to use exsisting mods.
I'm looking for some good advice on each of my options, Thanks!
CivicSlug is offline   Reply With Quote
Old 09-29-2003, 08:54 PM   #2
take this problem as a blessing and replace the rods/pistons w/ aftermarkets and you'll be ready for +300hp(with turbo obviously)
so for about 1500$ total (includes labor so even cheaper if you do it yourself)you'll have basically a new engine that can with stand a good deal of boost.
Old 09-29-2003, 09:13 PM   #3
I agree...in this particular instance, Id rebuild as well...upgraded parts of couse
Old 09-29-2003, 09:58 PM   #4
CivicSlug
CivicSlug's Avatar
I do take this problem as a blessing, seeing how I do have/an had planned on installing a JSC. So rebuilding is the best idea?, Thanks. Any suggestions on which aftermarket comp. to go with, maybe even a rough estimate on prices.
Old 09-29-2003, 10:01 PM   #5
do you already have the JRSC?
Old 09-30-2003, 05:17 AM   #6
CivicSlug
CivicSlug's Avatar
Yes, I already have the JRSC, but it has not yet been installed.
Old 09-30-2003, 10:58 AM   #7
personally, i say sell the jrsc and get a turbo with the money you make from it
Old 09-30-2003, 07:26 PM   #8
hmmm well since you already have it, either sell it and get a turbo kit or better yet go ahead and rebuild the engine, put on the supercharger then when funds are available put on a turbo too.
Old 09-30-2003, 10:17 PM   #9
turbo/sc combo??
Old 09-30-2003, 10:22 PM   #10
CivicSlug
CivicSlug's Avatar
Thanks for the advice. Sorry, no turbo for me. The supercharger will be plenty... for now, maybe in the future if this engine holds up. Remember, I'm working on a budget. If I end up loosing this engine, then I'll think about it.
Can I get some ideas on what type/make of rods and pistons to use? What would be the best set up for my ride?
Old 09-30-2003, 10:25 PM   #11
turbo/sc combo??
yup!
Old 09-30-2003, 10:27 PM   #12
since you're just running a JRSC you could actually just use OEM components, a step up from that would be Eagle rods and SRP pistons.
Old 09-30-2003, 10:31 PM   #13
CivicSlug
CivicSlug's Avatar
Yeh? Whats with Turbo/SC combo?? That can't be what you meant, is it?
Old 09-30-2003, 10:37 PM   #14
yes! thats what i mean! just run the supercharger till you have enough for the turbo, then add on the turbo. resulting in good low end power and less turbo lag from the supercharger and lots of top end from the turbo. its the best of both worlds! granted you'll need to do some good tuning and have a standalone ecu w/ larger injectors. just something to think about.
Old 10-02-2003, 10:56 PM   #15
Shaved &/or Laid
Shaved &/or Laid's Avatar
sex
Doody Ej1
Yse.
Old 10-03-2003, 12:46 PM   #16
well sorry to say but with a turbo/sc combo one will cancell out the other. youll either end up with a sc or turbo in your run. most of the time the sc wins and you never feel your turbo kick in(becuase it doesnt).
ben
Old 10-03-2003, 01:20 PM   #17
ben
ummm no, you're wrong.
Old 10-03-2003, 01:29 PM   #18
dude...can i see some pics and dynos of this combo? I've thought about it before...but gave it up as just being some of my wild imagination...
edit**i know some rally cars do it..but id like to see it on a normal street car
Old 10-03-2003, 01:48 PM   #19
hmm i havent really seen any dyno sheets.
theres this: http://www.teammeguiars.com/feat_typer.asp
but it doesnt really give you any info.
most people just deal with a little lag from a well thought out turbo setup, and make all the power they want.
Old 10-03-2003, 01:58 PM   #20
yeah ive seen that too...oh well
i tried h-t and found nothin there either really...
no biggie
Old 10-03-2003, 02:48 PM   #21
you should take out a loan and be the first!
Old 10-03-2003, 11:51 PM   #22
loan...yeah right...I got enough things to worry about than another loan
Old 10-05-2003, 07:19 PM   #23
I think that thing is twin supercharged... not turbo/sc...
but this....
http://www.overboost.com/pix.asp?ima...P8020012_2.jpg
Has both (look below the twin turbo's).
Old 10-11-2003, 09:17 AM   #24
CivicSlug
CivicSlug's Avatar
OK, SC/Turbo combo, I hear you. I'll keep that in consideration. Sorry I haven't responded sooner, its been a bad week! I blew my rod, spent the last week with my mech looking at different options for this problem.
First; we were going to go with a JDM Civic Type R motor swap, including trans, ECU, and front suspention. That turned out to be a bad idea. More money would be needed in the long run to make it all work properly. So scratch that.
We decided that a complete rebuild was in order- not just a typical rebuild- a Civic 1.6L SOHC VTEC Blower motor.
See what you think about this?
Bored/Stroked, Port/Polish, Polished crank, Forged rods, Low-compression pistons, Twisted valves, Titanium springs, JR cam, Copper headgasket, -my JRSC-, Fuel pressure regulator, JR ECU upgrade, Stage III clutch, and all guages (boost,fuel press,oil press,h2o temp,a/f ratio) + all my other mods.
Installed with warrenty- (parts/labor) for the same price of a 1.6L SOHC VTEC new from "Jasper" or "Mid-Atlantic"
What do you think of that? Does it sound like a good deal?
Old 10-20-2003, 11:17 AM   #25
Mirkwo0dForest
so tell me... how would the sc cancel out the turbo... it's not like the turbo will stop work, as long as there's exhaust, there's turbo
Old 10-30-2003, 08:12 PM   #26
VR4_Craver
Banned
I was just gonna say that but that would certainly be neat to see that work..... Would you need to intercoolers though? And two different BOV or wastegates or something of the such?
Old 11-01-2003, 06:15 PM   #27
to see what work?
All of the things mentioned exist and have worked for people..
dual sc
dual turbo
turbo/sc
