Old 09-20-2003, 08:18 PM   #1
RONI UNDERWOOD
Motors
I HAVE A 93 CIVIC WITH A B18C1. I MAY BE GETTING A 93 TEG LS. SO MY QUESTION IS WILL MY HEAD FIT ONTO THE LS? AND WHAT ALL WORK WILL NEED TO DO TO THE BLOCK?
Old 09-21-2003, 03:01 AM   #2
tegfello93
You can put any b-series head on any b-series engine. You'll have to get a steel braided oil line, fittings, and a T joint to run the oil from the block (oil press. sender hole) to the VTEC Solenoid.You need to tap and seal an oil-line on the back distributor side of the head (shown in pic) and bore out two of the dowel pin holes on your new head. The dowel pins on the b18a1 (on ls block) are in the Back but the ones on the VTEC heads are on the Front so you need to enlarge the ones on the back of the head to 14mm to match your block (shown as #1 and #4 on the pic ). you will need new head bolts the b18c1 Ecu and of course new head gasket. Good luck, nice pick of new car.
Old 10-07-2003, 09:42 AM   #3
MAXed Out
6th Gear
MAXed Out's Avatar
Yes it will fit.
SHIFT_MyNuts
Old 10-10-2003, 11:49 PM   #4
LOL- yeah it will fit, have someone else do the work, and no matter what anyone tells you, never spin it past 8000 RPM, fully built, or 6800 with stock internals.
