Old 09-16-2003, 03:51 AM   #1
thekid
h22a into a eg?
will a h22a bolt into a 92-95 hatchback or does it need custom work to fit in?
Old 09-18-2003, 06:09 PM   #2
Shaved &/or Laid
Shaved &/or Laid's Avatar
not worth it. WAY too much work. and you can undo it, you gotta cut transmission mounts.
Doody Ej1
Yse.
Old 09-21-2003, 10:38 AM   #3
Pikachu
Well, it does take much work but the rewards are big in the end. I currently have this swap. Wiring is probably your greatest problem. Also new axles from driveshaftshop.com should be bought because of how the motor sits, it causes undue stress on the axles.
To the original poster, it fits with mount kits from Hasport and quite a few others. Very little cutting is required.
