Old 09-15-2003, 09:25 PM   #1
OPAKRACING
D16a6 head gasket on a d16y8...
woudl this head gasket redce the d16y8's compression ratio? the d16a6 has a 9.1 and the d16y8 has a 9.6...so it seems as it would.
thanks
Old 09-15-2003, 10:48 PM   #2
only by .2
so you'll go from 9.6 to 9.4
why do you wanna drop compression anyway? 9.6:1 isnt very high.
Old 09-15-2003, 11:34 PM   #3
^for boost
not much of a change...not really worth it. Get an aftermarket y8 gasket thats thicker if youre looking for a more significant drop
Old 09-15-2003, 11:36 PM   #4
OPAKRACING
^for boost
so expensive tho....i was gunna get a 3mm greddy one that was 300 bucks, but i wanna get my turbo on.
Old 09-16-2003, 11:12 PM   #5
if you have a low displacement engine you don't wanna lower compression. the higher the compression the more low end power and less spool time. b16 and b18 have compressions of what? like 10.something :1 and they're fine w/ boost.
my advice would be to spend your money on MSD's little thing that retards timing under boost.
