Old 09-11-2003, 09:12 AM   #1
1992 Acura Integra wiring diagram
well brandon i need to wiring diagram for a 92 acura integra ls to install my brother's hornet alarm. the car does not have power locks tho.
thanks
Old 09-18-2003, 11:15 AM   #2
BrandonClaps
damn been really busy... here ya go man ;] hope i'm not to late
Code:
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|white or wht/blk |+ |ign harness or fusebox | | STARTER|black/white |+ |ign harness or fusebox | | IGNITION|black/yellow |+ |ign harness or fusebox | | SECOND IGNITION|blue/white |+ |ign harness or fusebox | | ACCESSORY|yellow |+ |ign harness or fusebox | | POWER LOCK|green/white |- |either kick panel *1 | | POWER UNLOCK|green/red |- |same | | PARKING LIGHTS +|red/green | |steering column | | HEADLIGHTS|red/yellow |+ |steering column | | DOOR TRIGGER|green/red *2 |- |dr kick panel/fusebox | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|green/black |- |dr kick panel/fusebox | |TRNK/HTCH RELEASE|manual | | | | TACHOMETER|blue | |distributor | | SPEED SENSE|yellow/red | |instrument cluster | | BRAKE WIRE|green/white |+ |brake pedal switch | | HORN TRIGGER|blue/red *3 |- |steering column | | WIPERS|blue and blu/yel |- |at switch | | LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door | | RF WINDOW UP/DN|blu/grn - blu/yel |A |in drivers door or dkp | | LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp | | RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp | | RADIO 12V|white/blue |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow/red |+ |radio | | RADIO ILLUMINATE|red/black |+ |radio | | POWER ANTENNA|yellow/white |+ |radio | | LF SPEAKER|blu/grn - gry/blk | |radio | | RF SPEAKER|red/grn - brn/blk | |radio | | LR SPEAKER|blu/yel - gry/wht | |radio | | RR SPEAKER|red/yel - brn/wht | |radio | Notes: *1 Easier to locate at passenger kick panel. On drivers side, wires are located high in kick panel. *2 Looks like a 14 awg. wire, but is mostly insulation. *3 High-current ground. Use a relay when interfacing with this circuit.
Old 09-03-2014, 07:01 AM   #3
Potrebovali
thanks for the list guys. it'll really help me.
dubli
Potrebovali is offline   Reply With Quote
Old 08-25-2022, 04:21 AM   #4
lotofsad1
Hulu did not immediately respond to Fox News
bcge on her wedding date. we were careworn because amber and her boyfriend were not even engaged, however she and her boyfriend claimed that they knew that turned into the date they were getting married. they have been goi
lotofsad1 is offline   Reply With Quote
