Old 09-08-2003, 12:33 PM   #1
ShagginJet
ShagginJet's Avatar
Fuxored a bolt, need help.
Was doing rear disk swap. One of the bolts won't unbolt, it just spins freely.
What can I do?
RECENTLY UPDATED!!! 5-20-04
Old 09-08-2003, 12:43 PM   #2
autocrossthugg
autocrossthugg's Avatar
can you grab the head with some vise-grips and pull it out?
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
Old 09-08-2003, 12:50 PM   #3
ShagginJet
ShagginJet's Avatar
Tried that, no go.
Old 09-08-2003, 02:29 PM   #4
what bolt are you talking about ?
Old 09-08-2003, 02:36 PM   #5
^right...that might help
Can you tell if there is a nut on the other end of it? Is the body of the part your removing threaded?
Old 09-08-2003, 03:31 PM   #6
ShagginJet
ShagginJet's Avatar
It's the bolt that holds the trailing arm up to the car. One bolt is completely stuck and the other hole mis threaded. It's the only bolts that go straight up.
Old 09-08-2003, 03:47 PM   #7
just get a torch and warm up the bolts. they should come out. make sure you don't burn yourself or the car.
Old 09-08-2003, 04:06 PM   #8
^yeah...thats about the only thing I can think of at the moment that might work...
Worst thing is that the nut thats welded up in the chassis came off the welds...if there is a nut...it could be threaded all the way up (im not sure)...but that seems unlikely becuase of whats happening.
Try using some vise grips (get a really good hold on it) and pull down WHILE turning it...that may hold the nut from spinning, thats up in there (again, if there is a nut)
Old 09-08-2003, 08:44 PM   #9
or if its possible get a rotary cutter and cut the head off. bang or drill the shaft through and re tap the hole if necessary. that's probably a last resort option though. Although I will say that drilling into bolts does work, I've done it many times.
Old 09-08-2003, 10:25 PM   #10
^Ive only had 1 success with that...a 1/5 success rating isnt to good imo. Each time I got broken exractors instead...but I was using small extractors.
Old 09-08-2003, 10:44 PM   #11
ShagginJet
ShagginJet's Avatar
I think I'm gonna cut the botl, drill the hole out, tow the car to a shop and have them weld in a stud, then I'll just NUT the trailing arm to that.
What do yall think?
LOL, I said " I'll just NUT..."
Old 09-08-2003, 10:48 PM   #12
do you think you could gain access to it? I mean to the other side to put a nut on
Old 09-08-2003, 11:00 PM   #13
ShagginJet
ShagginJet's Avatar
nope. It's in this cavity that you can tell is sealed on all sides. Spent about 3 hours brain storming on how i was gonna get my self out of this mess.
You think if I didn't have that piece bolted and rolled the car onto a flat bed tow truck, think that'd be a problem?
Old 09-08-2003, 11:04 PM   #14
as long as its just rolled onto a truck/trailer, and theres 1 bolt...oh wait...the other ones screwed up too.........id jack it up on the way.
Old 09-09-2003, 12:39 AM   #15
can't you look at it from under the backseat ?
Old 09-09-2003, 12:45 AM   #16
ShagginJet
ShagginJet's Avatar
I'll rip that apart just to double check but I'm 95% sure that it's sealed.
