Old 09-06-2003, 04:32 PM   #1
cruzincivic
cruzincivic's Avatar
Skunk 2 or B&N Short Throw
Hey everyone,
I'm planning on ordering either a Skunk 2 or B&N short throw shifter but I don't really know the big difference between the two. What does the dual bend(Skunk2) shifter do for the shift? I know the Skunk is about $110 while the B&N is around $70. Any other major difference or is it only preference...
Thanx
cruzincivic is offline   Reply With Quote
Old 09-06-2003, 05:52 PM   #2
i have no idea what the difference in them is, all i know is that I like my DC sports shifter alot.
Old 09-06-2003, 07:00 PM   #3
heh...Ive had both
I like the skunk2 dual bend model better than the straight b&m shifter...it sits a whole lot closer to me, even though the b&m shifts are shorter
Old 09-06-2003, 08:49 PM   #4
cruzincivic
Thanx pdiggitydogg,
I was worried about the position of the shifter, and I would rather have it closer to me.
I'm going with the skunk2
Old 09-06-2003, 09:28 PM   #5
more opinions here:
http://www.hstuners.com/forums/showt...threadid=11213
Old 09-07-2003, 04:08 PM   #6
cruzincivic
yea, i already reseached them on the forum but narrowed them down to those 2.
I already ordered the skunk2 anyway.
thanks though
Old 09-07-2003, 04:20 PM   #7
on the skunk2 model: if you tighten the lock-nut too tight it wont shift or it will be super hard. So make it just a bit looser than you really want to; it wont come off because its a lock nut, and you'll be able to shift.
be sure to use some white lithium grease (or similar) to lube up the shifter ball (pivot point) as well
Old 09-07-2003, 06:55 PM   #8
cruzincivic
ok thanks I also brought some energy suspension bushings as well so i'm hoping those are better than the stock bushings
Old 09-07-2003, 10:34 PM   #9
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
where can i purchase this so called lithium grease?
RICE....is good
Old 09-07-2003, 11:30 PM   #10
White lithium grease can be found at any auto parts store (murrays, autozone, that place that starts with a Kra__), hardware stores (ACE carries it in tub form instead of spray), and probably KFart, target, meijer, walmart, etc.
I like the spray kind, but having a tub of it is great too (for those things that need more than enough grease)
Old 09-08-2003, 09:51 PM   #11
sohc_vtec 2NR
thanks pdig! can't wait to intall my S.S. good thing my school has a lift for me to use!
RICE....is good
Old 09-08-2003, 10:30 PM   #12
lift?! you lucky dude...I am seriously jealous
Old 09-09-2003, 10:12 PM   #13
sohc_vtec 2NR
actually 2 lifts.. but the other has our "project" GMC scyclone (sp?) that burned and we have worked on..
so yes i'm lucky to have that in my school
RICE....is good
