Old 09-03-2003, 10:34 PM   #1
cashizslick
Finally Finished My SWAP!!!
Hey all - its good to be back!
Ok, so i finished my project for the summer - to do an engine swap on my car. I got a JDM B16A SIR-II from www.Hmotorsonline.com. The swap took longer than i had originally hoped because since this is a JDM motor, my stock wiring harness would not plug in properly. Other than the wiring problems (which are all set now) the rest of the motor went in just fine.
My car is now a whole new animal - much faster than it used to be. It needs to go back to my shop for some minor stuff (headlight, new belts, brakes) but the car is running real good.
To anybody thinking of doing and engine swap - it was definately worth it!
Old 09-03-2003, 10:36 PM   #2
good to hear that. post some pics
Old 09-03-2003, 10:54 PM   #3
cashizslick
I will when i get my car back from the shop, its a real mess now - junk everywhere, plus its real dirty under the hood.
Old 09-03-2003, 11:00 PM   #4
cashizslick
Old 09-04-2003, 10:00 AM   #5
cashizslick
Here is a pic of the motor in my car before the swap was done.
Old 09-04-2003, 11:37 AM   #6
so you already had a b16 in there? but good job on the swap, i know wiring can be a huge pain
Old 09-04-2003, 04:21 PM   #7
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
congrats! so did you do the swap or had somebody do it? u lucky SOB!
RICE....is good
Old 09-04-2003, 05:22 PM   #8
cashizslick
I had someone else do it - but man. . . . it was expensive.
Wiring was definately the biggest problem, since the motor was JDM, the plugs had to be run through the harness so the motor would run right.
Old 09-04-2003, 07:44 PM   #9
get some 1/4mile times now!!! thats an order.
Old 09-04-2003, 09:08 PM   #10
cashizslick
I would, but im so poor now, i have to money to go to the track LOL.
Old 09-04-2003, 09:10 PM   #11
cashizslick
What do you guys THINK i would run?
Old 09-04-2003, 10:44 PM   #12
Shaved &/or Laid
Shaved &/or Laid's Avatar
14.5
Doody Ej1
Yse.
Old 09-04-2003, 11:58 PM   #13
pauls-si
Cool.....are you running the stock clutch?
Old 09-05-2003, 12:47 AM   #14
i think you'll run low 15's. I hope you prove me wrong.
Old 09-06-2003, 01:27 AM   #15
Props..... it looks like you retained the A/C huh? I was looking at that site and the motor pricing confuses me. How much was your motor and what did it come with? If you dont mind me asking
Old 09-06-2003, 03:56 AM   #16
SphynX
Hey, how much did it cost for someone to drop it in for you, and how long did it take. Hope you dont mind me asking either. Im getting a swap and need to know roughly how much its gonna cost.
Thanks
Steve
Old 09-06-2003, 09:57 AM   #17
cashizslick
I paid about 2350 for the motor, an extra 300 for the LSD tranny, and then i had to pay shipping.
Old 09-06-2003, 10:02 AM   #18
cashizslick
Thanks
Steve
Well, The actual installation of the MOTOR was real easy, only 3 hours to take out the old motor and put in the new one (with the axles, alternator, and all that other stuff).
The problem i ran into was that since i am using a JDM motor, there are connectors on parts of the motor that were in the wrong place - so this swap was not plug and play.
"steve" at HMO said that i should just take my stock harness and plug it into the new motor and run a knock sensor and extend my O2 sensor, but that was not the case.
The shop that did my swap showed me that there was no way to get my stock harness to plug in, and instead of doing the ghetto thing by running wires throughout the engine compartment, they rewired my wiring harness to fit the new motor : that was deffinately the most unexpected and expensive part of the swap.
If you are going to do a swap, do not go with a JDM motor, use a USDM one because it WILL be a plug and play swap.
Old 09-06-2003, 10:22 AM   #19
cashizslick
$2,350 for B16A2 Chngvr, $300 for LSD equipped Transmission, $250 for shipping plus a 3% credit
charge = $2,987.
These things always seem to cost more then we intend.
Old 09-06-2003, 10:35 AM   #20
jjcivic92
jjcivic92's Avatar
Man, that's awesome though. I'm wanting to do an engine swap in my hatchback - for real. I'm running a d15a - it sucks. yeah, that swap was really expensive, but worth it right? That's awesome man.
jjcivic92 is offline   Reply With Quote
Old 09-06-2003, 02:08 PM   #21
pbateson
Engine swap are more expersive than normal engine
Old 09-06-2003, 04:24 PM   #22
That is not bad for a JDM/LSD tho. I've seen a B16A swap go for $3500 (including labor).
Old 09-06-2003, 06:10 PM   #23
charge = $2,987.
how much was labor???
Old 09-06-2003, 06:59 PM   #24
pimp
Old 09-07-2003, 12:09 AM   #25
cashizslick
pimp
LOL, well, it does feel good to know that i am driving a car with a real honda motor in it - Ive talked about doing this for so long, i am even having trouble believing it!
Ok, I initially paid my buddies shop 400$ to put in the motor - they did all that except for the wiring, which i had to get the car sent out to another shop to have done - those guys did an excellent job re-wiring my wiring harness to fit the new motor, but they also charged 70$ an hour - for 32 hours of wiring nonsence - but hey, thats just cause i had the JDM motor.
Even though this swap turned out to be much more expensive than i had originally hoped, it was sssooooooo worth it.
***** i must be honest and say that if i had known it would be much more expensive and tiring to get the JDM motor to work, i would have kept searching junkyards for a USDM B16a or B18c.
The bottom line is that it was worth it.
Old 09-07-2003, 01:05 AM   #26
please tell me this is a typo and you didnt pay for 32 hours of wiring at 70$ an hour.
Old 09-07-2003, 01:19 AM   #27
God I hope not.
Old 09-07-2003, 01:23 AM   #28
cashizslick
No Typo - i know it is ludicrous, but i was desprate to get my car back.
In order for the wiring harness to fit right, there were 300 wires that had to be re saudered to fit properly.
That is why i wish i knew that the JDM motor did not plug right in, if i had, i would have done things very differently.
Since i took my car to a quality place, they completed the wiring in the most expensive way possible, and i was unable to do anything about it because i was desperate, desperate to get my car back.
**Please do not mention that anymore (the 70$ an hour thing) i feel like such a moron for having this done.
Steve from HMO told me that my stock harness would plug right in, but it did not - i saw for myself that things are never as easy as they seem.
Old 09-07-2003, 01:35 AM   #29
i'm speachless......
Old 09-07-2003, 01:46 AM   #30
jjcivic92
jjcivic92's Avatar
Man, it's all good. You live and learn, dont' worry about it. Just enjoy your new engine. Who am I to make fun I'm pushign like 70 hourses - HAHAHAH!!!!
Old 09-07-2003, 02:10 AM   #31
acclude
i was wondering if you paid cash for all this worthless work you had done. did you even think about how much hp per dollar you were spending?
you should feel like more than a moron... how about a worthless, stupid money wastin' non import knowledge having piece of slimy imbred shit.
Old 09-07-2003, 08:20 PM   #32
cashizslick
Turns out the only way to get a job done right and not ghetto is to do it the right way.
Steve From HMO and all the other people who i had talked too (HAsport) insisted that the JDM b16 was a direct plug in swap. You have no idea how mad i was when i heard that the motor would not plug in.
So, instead of ghetto wiring the thing, i decided to have this done the right way - through the harness. I have absolutely no communication problems, everything works (including dash lights) and A/C.
I am quite irate at the fact that HMO expected me to ghetto wire the motor - that is why they said it was a direct plug in swap.
Believe me, this is no understatement.
I dont understand, all the reaserch i have done for the past year and all the people i talked to said this was a direct plug in swap - guess not and it really sux for me.
Old 09-07-2003, 08:24 PM   #33
cashizslick
When you have no car for a month, and are moving away, you will be surprised how desperate you will be to get your car back.
Old 09-07-2003, 09:08 PM   #34
relax...... nobody's perfect. BTW, welcome to HStuners
Old 09-07-2003, 09:52 PM   #35
acclude
true we're only human... thanks for the welcome, catch you guys later.
