Old 08-20-2003, 04:25 PM   #1
na975
Ground Control
Hi, im new here. Ques: can i use the stock strut boots w/GC's, these springs are 2.50 ID , do you know if the boots fit inside the spring?
Old 08-20-2003, 06:15 PM   #2
vtracer20
if u use your old strut they will blow if u go under 2inches....maybe less than that....u need to upgrade ur struts and get a camber kit if u want to go under 1.5inches
Old 08-20-2003, 07:58 PM   #3
na975
strut boots
you misunderstood- can i use the stock strut boots to protect my struts when install my GC's- will they fit ?
Old 08-20-2003, 08:22 PM   #4
vtracer20
yeah u should use them.....unless someone says otherwise
Old 08-20-2003, 10:24 PM   #5
well really you can't use them. they are going to hit the coilover sleeve pretty bad if you lower more than 1". did u read the instructions that came with them ?
Old 08-20-2003, 10:53 PM   #6
vtracer20
damn i was proven wrong.....crap
Old 08-21-2003, 03:13 PM   #7
na975
no.
