Old 08-16-2003, 10:58 PM   #1
iguess
d16z6 engine block
i sucked up water through my cold air intake which i didn't install an airbypass valve. my engine died and i tried restarting it a lot of times. the engine started and i have been driving it for a wk. its been making a knocking noise so i decided to take the engine apart. once disassembled, i found that the 1st and 2nd connecting rod was bent. the only damage that it made to the block is the very bottom edge where the piston is at its lowest. there is no visible cracks within the cylinders. my question is, am i still able to use the block? any feedbacks are appreciated. thanks!
