Old 08-10-2003, 06:49 PM   #1
civicsystm
Headlight Strobe Install question
i just bought headlight strobes for my civic, i got a 98 LX where the hell could i drill a hole to place the strobe in the headlights?
Old 08-10-2003, 10:50 PM   #2
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
whereever you want...
i drilled mine on the inside "side" of the headlights...right between the first and second reflector..
i suggest you open up your headlights and drill from the inside, that way you won't have little plastic fuzz on the inside of your headlights AND you won't risk damaging the reflector...
if you want i can take a picture to show you
RICE....is good
Old 08-11-2003, 12:53 AM   #3
accord98lx
uh...what is a headlight strobe?
Old 08-11-2003, 02:19 AM   #4
DavidH
i *think* its just a strobe light that gets mounted inside the headlight housing. Just be careful to seal up the hole well, dont want any fogging....
Old 08-11-2003, 12:10 PM   #5
Mischief(LTS)
yea.. use the clear silicone sealant, and LOTS of it. this will ensure proper seal :PP
Old 08-12-2003, 12:11 AM   #6
civicsystm
tell me how the heck to take out the headlight, i took out the top two bolts and it wouldnt budge, and a picture would help thanks
Old 08-12-2003, 02:11 AM   #7
DavidH
for the 98 LX im about 90% sure the bumper has to come off before the headlights will come out.
Old 08-12-2003, 10:34 PM   #8
sohc_vtec 2NR
there is another bolt on the outer side of the headlight (turn signal side). you'll have to pull part of the fenderwell plastic to get to it. i believe there's only 3 bolts per headlight, but i could be wrong...i'll take the picture tomorrow for you
and i didn't have to take the front bumper out..
RICE....is good
Old 08-13-2003, 12:34 PM   #9
DavidH
i was wrong then =P isn't a first lol
Old 08-13-2003, 12:54 PM   #10
WhiteSleeper
You're gonna have to take the bumper off, there's a bolt on the outside and one in the front.
Old 08-13-2003, 10:40 PM   #11
sohc_vtec 2NR
i didn't have to...
RICE....is good
