#1 |
Rsx type s
can someone answer my ? please would a rsx type s motor fit in a 97 gsr???
#2 |
no
#3 |
no i did a lot of research trying to do t his swap in an eg6, the motor has been completly reversed, and the k20 is an ob3 motor wich makes it that much harder, if it was done it would be very expensive because every thing would have to be custom. places like HASPORT wont even do R&D on a mount kit because the amount of the swap is not worth the money.
You might as well try to put an F20C (s2000) in it or an sr20det but if you do do the swap i would give you mad props as well as probably every other honda tuner in the us because you would be the first |
| Thread Tools | |
| Display Modes | |
