Old 07-17-2003, 04:08 PM   #1
RONI UNDERWOOD
Cams
I NEED HELP PICKING A SET OF CAMS. I GOT A B18C1. WITH HEADER ,INTAKE,FULL EXHAUST,VENOM INJECTORS, AND A 65MM THROTLLE BODY.I HAVE PLANS OF STROKING THE MOTOR, AND A 50 SHOT OF NOS. PLEASE MAKE SUGGESTIONS. I LIVE IN A TOWN THAT THE IMPORT SCENE REALLY SUCKS. SO PLEASE HELP
Old 07-20-2003, 02:16 AM   #2
a96710
a96710's Avatar
Toda, Skunk2, Gude
Old 07-21-2003, 09:40 PM   #3
Jazn671
Jazn671's Avatar
TODA - 2 thumbs up!
Suja 1 Motoring
502 E St. Charles
Carol Stream, IL 60188
630-407-0711
www.suja1.com
AIM:Jazn671
Old 07-22-2003, 06:53 PM   #4
You can't stroke and run Toda Cams, except for the Spec A. The Spec B and Spec C both require a high redline. The same is true of the Gude and Skunk2, though not as drastic.
I would recommend EITHER stroking or upgrading your camshafts, but not both. It would be like putting high compression pistons in a boosted motor.
If you've decided on increasing displacement and swapping camshafts, I would bore the cylinders and go with either The Toda Spec B or Jun Stage 2 cams.
Old 08-04-2003, 05:45 PM   #5
I say...TODA
why the hell is it in all caps?
