Old 07-17-2003, 11:48 AM   #1
travismitchell
how do i?
How do I take out the gauge cluster on a 1992 civic hb. I have the 2 screws out of the top and I don't know where else to look for some.
I shouldn't have to take the whole dash apart to do this do I?
Old 07-17-2003, 12:15 PM   #2
ShagginJet
ShagginJet's Avatar
I've done it on my 3rd gen, really easy too. There are usualy two screws on the front that you have to look at a wierd angle in order to see them. Then there are usually two screws on the back that are hidden. But that's for a 3rd gen. Not sure on the 4th gens. It should be pretty obvious though once you look around.
RECENTLY UPDATED!!! 5-20-04
Old 07-17-2003, 03:28 PM   #3
it's just the two screws... then it's all clips...
you have to pry it out... it kinda sucks and is too hard to explain...
but you pry out from the bottom...
once it's loose you have to dis-connect the clock and hazard switch...
Old 07-17-2003, 03:36 PM   #4
no hidden screws in the vents ?
Old 07-17-2003, 07:50 PM   #5
travismitchell
well i figured out how
the 2 screws then i had to remove the hazard switch and remove a screw under there
thanks anyways
Old 07-18-2003, 02:09 AM   #6
95DX
95DX's Avatar
how did you get the hazzard switch out? I think I basicly want to do the same thing on mine
Old 07-18-2003, 04:11 AM   #7
sc0rch
hazardswitch comes out easily....pop the actual button off 1st with something flat......then kinda pry it out.....thats the easy part....the left vent is the hardest....well atleast on mine....it always wants to fight me
