Old 07-16-2003, 11:16 AM   #1
Ryub
Best swap for a 94 2 door civic
I'm new with the swap topic. I need to know what is the best swap for a 94 civic 2 door. I have 3,500 to spend on the engine or an engine/turbo. Should i go with a 92 integra ls motor and a turbor or should i just get a gsr motor ?? Thanks guy
Old 07-16-2003, 12:07 PM   #2
I say GSR engine. You can always turbo later. The GSR compression is not that bad to turbo. There are so many misconception about mid range compression + turbo. Get a GSR swap and start with a higher base HP.
An LS engine is not bad neither but your $3500 will not be enough with an LS plus turbo especially if you get a turbo kit. The turbo kit alone will run u dry. Are you doing the labor yourself?
If you want to be a little different, try a B20 swap. It has a higher torque base and is a great platform to turbo as well....
Old 07-16-2003, 12:10 PM   #3
Ryub
What model GSR would be the best deal for me ?
Old 07-16-2003, 12:12 PM   #4
Ryub
or should i just go with the ls/vtec....and then later put on a turbo...how much would the ls/vtec run me...I want to do it right...preferable the b20
Old 07-16-2003, 12:13 PM   #5
All GSR's are B18c1 engines. Any of them will suffice.
An LS/VTEC can de done with a little over what you are paying for an LS swap. It all depends on where you're getting it done from. A CRVTEC is just about the same. But it is hard to find a B20 engine. An LS/VTEC and turbo can be an amazing machine man, eventhough I'm not a fan of the conversion. This coonversion can be unreliable, IMO......
Old 07-16-2003, 12:15 PM   #6
Ryub
whats the cheapest place to get one?
Old 07-16-2003, 12:17 PM   #7
Where are u located? If you're in SoCal, try: www.ARDperformance.com or www.speedupgrade.com
U might be able to get the engines from them. Installation is another story....
Old 07-16-2003, 12:19 PM   #8
Ryub
i am in charlotte NC
Old 07-16-2003, 12:23 PM   #9
Are you willing to drive to Virginia Beach? If so, email me at arceoa@porter.navy.mil
There is an awesome shop here who can help u out.....
Old 07-16-2003, 01:36 PM   #10
Ryub
yeah i am willing to driving to viriginia..it isnt far from..what is the name of the shop..and what are the prices....
Old 07-16-2003, 01:45 PM   #11
Ryub
i dont mind spending 3500 and getting my car up to about 200 hp,
i can wait on the turbo....later after my motor is built up to the max for it
Old 07-16-2003, 02:09 PM   #12
^ you won't have 200 hp with ANY swap.... unless you get a REALLY good running type R... but that's certainly not 3500...
also I'm not trying to insult you but I think you should save the money and do a LOT more research... you don't want to jump into this by throwing money and praying...
there should be a plan based on YOUR knowledge and experience of what you want in the long run and the best way to go about it...
if you ask me making any non-vtec into a vtec is a silly idea... if you want vtec get a vtec block... the non-vtec blocks are NOT designed for high reving and generally don't last too long... sure you COULD be the exception but I HIGHLY doubt it...
If I were you I'd get a gsr or ls swap... if you go ls, the turbo down the line should get you to whatever goals you have if you have the money...
Same goes for the gsr but with a little more cost up front but more power and the ability to hold the gears for a little longer...
In my opinion the best thing to do would be to figure out what YOU want.. by reading and doing research not by just asking what someone else thinks...
just my .02
Old 07-16-2003, 03:07 PM   #13
Ryub
I am going with the gsr swap and turbo it up later....trying to find a place with the cheapest gsr .....i'll worry about the turbo at the end of the yr
Old 07-16-2003, 03:28 PM   #14
I PM'd you Ryub
Old 07-16-2003, 03:30 PM   #15
what model civic do you have???
Old 07-16-2003, 03:35 PM   #16
Ryub
i have a 94 civic ex 2 door ...what does PM mean? this is my first day on the forum
Old 07-16-2003, 03:42 PM   #17
have you considered just turbocharging the motor you have?
You dont gotta do a swap to be fast.
Old 07-16-2003, 03:49 PM   #18
Ryub
I thought about just turboing up the motor i have but i would like to have a faster motor to play with plus the gsr would be able to handle more power
Old 07-16-2003, 03:53 PM   #19
Ryub
thermalfi'd16
I didnt not get your PM yet
Old 07-16-2003, 03:58 PM   #20
PM= Private Message
It should be there now bro......
Old 07-16-2003, 04:04 PM   #21
Ryub
thanks man....let me check
Old 07-16-2003, 04:09 PM   #22
Ryub
Where can i purchase a GSR motor for the best price....
Old 07-16-2003, 06:08 PM   #23
how long has this thread been here?! How did I miss it completely?...I mean Im here ALL THE DAMN TIME...........yeah......
anyways...
www.hmotorsonline.com is the most highly praised online shop for honda motors, besides www.importautosalvage.com. Both are very good and will give you a decent price on GOOD CLEAN motors
Old 07-16-2003, 08:13 PM   #24
It started today man. You're okay . It just happened to be that we were both online at the same time.
Old 07-16-2003, 09:00 PM   #25
how much power do you plan on making?
Old 07-16-2003, 11:41 PM   #26
A built turbo d16 won't make the same power as a stock turboed gsr... and it won't have ANYWHERE near the torque either...
I'm not slamming turboed D's but if he's looking for big power in the end, dumping money into a d16 is NOT the answer.
So what are your power goals?
Old 07-17-2003, 12:22 AM   #27
I think if your looking for a car to make big power with, a civic is not the answer.
In the beginning everyones looking to make BIG power till they realize that a FWD car isnt really worth dumping all kinds of money into.
There are people making +300hp with just aftermarket pistons/rods(about 1k$) in dseries engines.(and a turbo, obviously)
Old 07-17-2003, 08:28 AM   #28
Ryub
I'm hoping to hit around over 300 hp after i am down with the swap and the turbo if possible. I'll be happy with 300 hp on the two door civic
Old 07-17-2003, 03:31 PM   #29
^you want another platform...
a 300hp civic will be all but undrivable... unless that's a peak number...
even with a dif you'll be doing nothing but spinning wheels...
Is this a track car only or street driven?
Is this your first car... or first project?
Old 07-17-2003, 03:36 PM   #30
Ryub
this is my first project...i have a couple of other cars to drive arouind
Old 08-29-2003, 10:45 AM   #31
Ryub
So what GSR motor do I go with ...the easy to fit into a 94 Civic EX 2 Door coupe.....
Old 08-30-2003, 02:30 PM   #32
Like has already been said like 50 times....
ANY gsr motor will do... obd1 will be easier to wire... either way... I don't think you have ANYWHERE near the amount of info you need to make a good decision.. or to end up with anything...
Are you going to be doing this yourself or sending it to a shop?
If a shop then let them decide... they'll do what they do...
If it's you then I think you have a LOT more research to do.
Old 08-30-2003, 03:04 PM   #33
Shaved &/or Laid
Shaved &/or Laid's Avatar
yeah man. GSR is ONE KIND of motor. b18c1 period. theres no better kind of GSR they are all the same.
also, try looking into homemadeturbo.com. Maybe youll be able to throw some kinda junkyard turbo setup on there. A prefab kit is no better, just a little less work for a WHOLE LOT more money. also, if you know anyone from hondatech, they might be able to get you a hookup on the DRAG turbo kit cauyse theres a place selling htem really reall really cheap to ht members, if hteyre still doing it. www.honda-tech.com is a good place to ask questions too. Theyre a more advanced forum as far as pure speed/ functional cars.
Doody Ej1
Yse.
Old 08-30-2003, 04:07 PM   #34
umm there are 2 gsr engines: b18c1 for the 94-01 integras and b17something for the 90-93 integra (very very rare thou).
Old 09-02-2003, 02:04 AM   #35
jaberg00
well u got a bit of money aight, this is what u do Get a B20B thats 126hp or B20Z which is 146hp i would get that B20Z it only cost about $800 search for a b16a or b18c1 head and bolt it up, that combo is better than the GSR it self way mor torque and hp, then i would suggest u get a LS tranny, and like that guy said well he dont kno what he is talking about the non-Vetc block can withstand high rev trush me.
Old 09-05-2003, 08:37 PM   #36
Shaved &/or Laid
yeah with a turbo
and i assumed he wanted the same model year. my bad
Doody Ej1
Yse.
Old 09-12-2003, 02:48 PM   #37
drdingo21
drdingo21's Avatar
Im surprised this idea hasn't been throwen out yet...
There is also the 225 hp H22 engine from a prelude. The engine itself is around 2k but you will have to upgrade the suspension of the car.
Its not near as bad as most people make it out to be. I drove one 2 weeks ago (the guy had just under 3k invested in it) the car handled great (don't remeber what upgrades he did to the suspension) and it was defintly fast.
Most people shoot down this idea because the engine is some work to fit into a civic, but once its done it is bad ass.
Old 09-12-2003, 03:02 PM   #38
youre forgetting the problem of breaking axles, NOT due to the extra power but due to the akward angle they sit at in a civic w/ a h22.
Old 09-13-2003, 12:57 PM   #39
cashizslick
THe B16A is a great motor too - although the GSR is slightly superior, but i must say - the New motor in my car has made a BIG difference in the way the car behaves - im very pleased with it.
Old 09-13-2003, 01:01 PM   #40
cashizslick
The Civic chassi is not designed to handle an H22 - plain and simple. The motor sits awkwardly in the car/not to mention it's power numbers require you to greatly beef up ur suspension in order to be able to drive properly.
BTW, if you put an H22 in ur car, consider it a car that will only run "the straight and narrow" cause the added weight on your front end will make you corner like crap.
