Go Back   HSTuners > Classified Ads > Parts For Sale/Trade
Old 07-14-2003, 01:11 AM   #1
hondav6
>>>Lots of parts, NEED MONEY BAD!!! Help me out!!!<<<
Here is a list of the majority of parts that I have for sale, this does not include a lot of the odd’s and in’s that is still left with the car. I will be adding more to this list when I find more parts to list. Pictures are available only upon request.
Prelude Items
>94 H22A1 Prelude Motor/Tranny, this motor/tranny has about 25k on it. I was only able to put 200 miles on the car before it was stolen. Asking price: $2000 for local pick up, if your not local, you take care of all the shipping charges.
>H22A1 Red Valve cover: $90
Honda Accord AFTERMARKET Parts (all the accord parts came off of a 94 f22b1 (vtec) unless stated otherwise)
Engine Parts
>94-97 Accord Custom VTEC head, KG Precision head, Stage 5 P&P, SSI Valves and retainers: Cost $1600 to have done, asking $1000, has only 5k **DROPPED TO $900**
>94-97 Accord Fully built bottom end. Cylinder #2 and #3 needs to be re-honed very very slightly because of light schoring. The bottom end consists of Aris 8.5 : 1 Forged Pistons, Crower Rods, Golden Eagle “Godzilla” Sleeves. Not much to get the work done being that the block is already out, or if you know what you doing. This block alone cost $2300 to have completely done. I am asking $1400 because of the work. **DROPPED TO $1200**
>Accord JDM Manual Transmission, Cryogenically Treated, Red line oils and lubricants: $1000. (**DROPPED TO 900**) I will include a Stage 4 Clutchmasters Clutch with the lightened flywheel for $1400 **DROPPED TO $1300**
>Accord P&P custom intake manifold: $Make offer$
>Accord P&P big throttle body: $Make offer$ **Might be sold for $125**
>Energy Suspension motor mount: $Make offer$
>Crane Fireball Hi-6 ignition, Nology Pro-Fire coil, New Distributor (for the
Vtec accord) with MSD distributor cap: $390 **DROPPED TO $350**
>MSD Distributor Cap: $25
>94-97 Red Nology Hot-Wires with independent grounds: $100
>Accord (possibly others) AEM Silver Fuel Rail: $85
>Accord (possibly others) AEM Red Tru-power Pullies with belt: $100
>Accord (possibly others) Unortodox Racing Underdrive Crank pully: $190
>Accord (possibly others) Unortodox Racing Ultra Tr Race Adjustable Cam
Sprocket: $200 **DROPPED TO $190**
>Accord Blue SMACO Performance Radiator Hoses: $50
>Accord Fluidyne Radiator with fan (slightly dented in the rear of the radiator): $400
>Accord Custom 3” SS Mandrel bent exhaust: $Make offer on local pick up$
>SX Engineering High flow fuel pump with custom fittings, AN-6 SS lines, AN-8 SS lines, and filter (fuel set up when i was boosting, there is more than $500 in just lines with this set up): $750
Exterior Styling
>94-97 Accord Euro Clear Sidemarkers, with red japan bulbs: $10
>94-95 Accord Red Clear Tail lights: $50
>94-97 Accord Custom Piaa projector headlights: $175
>94-97 Blitz Blue Class bumper with mesh: $175 Local
Suspension and Breaks
>Eibach sportline/Koni front & Neuspeed race/kyb agx rear suspension: $Make offer on this set up$
>Power Stop rotors in front and in rear: $200 for all
>Goodrich stainless brake lines: $Make offer$
>Endless breaks: $Make offer$
>PBR Metal Masters Performance break pads, NEW: $75
>Suspension Techniques anti-sway bars ( f & r ): $175 for both, or $100 each
>OBX top rear strut bar: $Make offer$
>DC Sports rear lower tie bar: $Make offer$
Honda Accord STOCK Parts (all the accord parts came off of a 94 f22b1 (vtec) unless stated otherwise) If there is something that you don’t see on this stock part list, ask me about it because I’m almost sure Ill have it.
>94-95 Accord EX (Vtec) Manual Computer (OBD1): $100
>94-97 Accord Toupe Stock Seats with Power Driver: $300 Local
>94-97 Accord Stock Headlights, MINT: $100 **DROPPED TO $80**
>94-97 Accord stock tape deck: $Make offer$
>90-97 Accord Stock Springs: $Make offer$
>Accord Ignition Wires: $Make offer$
>Accord Vtec Distributor: $Make offer$
>Accord Fuel Rail painted red: $Make offer$
>Accord Alternator: $Make offer$
>Accord Alternator Pully painted red: $Make offer$
>Accord Crank Pully: $Make offer$
>Accord Horn (I have 3 of them): $Make offer$
>Accord A/C compressor: $250
>Accord A/C lines: $Make offer$
>Accord Front and rear stock rotors: $Make offer$
>Accord Stock front and rear breaks: $Make offer$
>Accord Stock 9006 Headlight bulbs: $Make offer$
>Accord Stock 9005 Headlight bulbs: $Make offer$
>95-97 V6 Accord Gauge cluster, can be used for parts for other model
accords: $60 **SOLD PENDING PAYMENT**
Accord/CL 2.2L Complete Turbo Set up
This is a complete turbo set up for your 2.2l vtec engine. All the parts listed below are not your cheap imitations, these are the real deal and will provide you with plenty of power and sound. This is everything you will need to get your 2.2l vtec boosting in a matter of hours. If you have the non-vtec but are interested in this set up, I will take off 350 from the price for the manifold
>Turbonetics T3/T04E turbo, Stage 3 Turbine, 50 Trim, .63 A/R
>Iceman Exhaust Manifold
>Custom 2 7/8” Downpipe
>MHI IC with all the piping, Intake to IC, IC to turbo
>42mm Red Tial wastegate
>50mm Red Tail BOV
>Turbonetic T-clamps (not cheap at all)
>Turbonetic Couplings
>Paxton 12:1 FMU
>Greddy 52mm White face boost gauge
>Carbon fiber single pod (double if you purchase the EGT Gauge with the set up)
>SS Oil feed/return lines
>Oil Catch can
Asking $2300 for the entire set up for the f22b1, if you have the f22b2 it would be $1950
These Items are related to the turbo set up, but are being sold separate, if your interested in purchasing these items with the set up, I will work something out for you.
>550cc RC Engineering Injectors: $260 **DROPPED TO $250**
>APEXI Super AVC-R (black jdm one): $275 **DROPPED TO $250**
>Greddy 52mm White EGT Gauge: $130 **DROPPED TO $120**
>Autometer 52mm A/F Gauge: $30
Miscellaneous Items (Car Related)[
>4 Red 10” neons: $50 **DROPPED TO $40**
>2 Purple 10” neons: $20
>Sony Graphic EQ (missing the wiring harness): $75/**obo**
>6x8 Infinity References, MINT: $65
>Panasonic In-dash DVD with A/V control unit, MINT: $1050
>New Red “Powered by Honda” Shoulder pads: $10
>Brand new H4 Hiper Industries Super Plazma Xenon Bulbs: $20
>98-99 Maxima SE 7 Color White face gauges: $20
>Polarg Hyper white 194 bulbs, 3 Pair: $8 a pair
>Polarg Hyper white 7440 bulbs: $15
>Motegi Tuner Lug nuts with key, in chrome: $50 **DROPPED TO $40**
>87-89 T-Bird GTO Black out headlight covers: $25
>T-bird/Cougar Chiltons Manual: $10
MIC Items (Not Car related)
>Bundy II Alto Saxophone: $600
>Nokia 3360 with OEM Case, aftermarket face, home/car charger, leather
case: $75
